代码挑战:迁移0元素|C#
Jet Ding 发表于 2021/07/23 14:20:24 2021/07/23
【摘要】 Given an array nums, write a function to move all 0's to the end of it while maintaining the relative order of the non-zero elements.Example:Input: [0,1,0,3,12]Output: [1,3,12,0,0]Note:You must do ...
Example:
Input: [0,1,0,3,12]
Note:
  1. You must do this in-place without making a copy of the array.
  2. Minimize the total number of operations.
方案:
    public class Solution
        public void moveZeroes(int[] nums)
            int index = 0;
            for(int i = 0; i < nums.Length; i ++ )
                if(nums[i] != 0)
                    nums[index++] = nums[i];
            while(index < nums.Length)
                nums[index++] = 0;
测试案例:
        [TestMethod()]
        public void Test1()
            Solution solution = new Solution();
            int[] nums = { 0, 1, 0, 3, 12 };
            solution.moveZeroes(nums);
            int[] expected = { 1, 3, 12, 0, 0 };
            for (int i = 0; i < nums.Length; i++)
                Assert.AreEqual(nums[i], expected[i]);
        [TestMethod()]
        public void Test2()
            int[] nums = { 1, 9, 8, 4, 0, 0, 2, 7, 0, 6, 0, 9 };
            int[] expected = { 1, 9, 8, 4, 2, 7, 6, 9, 0, 0, 0, 0 };
