代码挑战: 最大子数组 #Java
Jet Ding 发表于 2021/07/23 10:21:43 2021/07/23
【摘要】 Given an integer array nums, find the contiguous subarray (containing at least one number) which has the largest sum and return its sum.Example:Input: [-2,1,-3,4,-1,2,1,-5,4],Output: 6Explanation: ...
Example:
Output: 6
Explanation: [4,-1,2,1] has the largest sum = 6.
方案:
class Solution {
    public int maxSubArray(int[] nums) {
        int result = nums[0];
        int temp = nums[0];
        for (int i = 1; i < nums.length; i++) {
            temp = Math.max(nums[i], temp + nums[i]);
            result = Math.max(temp, result);
        return result;
测试案例:
    @Test
    public void test1() {
        Solution solution = new Solution();
        int nums[] = {-2, -3, 4, -1, -2, 1, 5, -3};
        int result = solution.maxSubArray(nums);
        Assert.assertEquals(result, 7);
    @Test
    public void test2() {
        int nums[] = {-2,1,-3,4,-1,2,1,-5,4};
        Assert.assertEquals(result, 6);
    @Test
    public void test3() {
        int nums[] = {-2};
        Assert.assertEquals(result, -2);
