【Mybatis】如何继承Mybatis中的Mapper.xml文件
石臻臻的杂货铺 发表于 2021/07/22 11:01:47 2021/07/22
【摘要】 最近在写一个 Mybatis 代码自动生成插件,用的是Mybatis来扩展,其中有一个需求就是 生成javaMapper文件和 xmlMapper文件的时候 希望另外生成一个扩展类和扩展xml文件。原文件不修改,只存放一些基本的信息,开发过程中只修改扩展的Ext文件形式如下:SrcTestMapper.javapackage com.test.dao.mapper.srctest;impor...
形式如下:
SrcTestMapper.java
import com.test.dao.model.srctest.SrcTest;
import com.test.dao.model.srctest.SrcTestExample;
import java.util.List;
import org.apache.ibatis.annotations.Param;
public interface SrcTestMapper {
    long countByExample(SrcTestExample example);
    int deleteByExample(SrcTestExample example);
    int deleteByPrimaryKey(Integer id);
    int insert(SrcTest record);
    int insertSelective(SrcTest record);
    List<SrcTest> selectByExample(SrcTestExample example);
    SrcTest selectByPrimaryKey(Integer id);
    int updateByExampleSelective(@Param("record") SrcTest record, @Param("example") SrcTestExample example);
    int updateByExample(@Param("record") SrcTest record, @Param("example") SrcTestExample example);
    int updateByPrimaryKeySelective(SrcTest record);
    int updateByPrimaryKey(SrcTest record);
SrcTestMapperExt.java
import javax.annotation.Resource;
* SrcTestMapperExt接口
* Created by shirenchuang on 2018/6/30.
@Resource
public interface SrcTestMapperExt extends SrcTestMapper {
    List<SrcTest> selectExtTest(@Param("age") int  age);
SrcTestMapper.xml
<!DOCTYPE mapper PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN" "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.test.dao.mapper.srctest.SrcTestMapperExt">
  <resultMap id="BaseResultMap" type="com.test.dao.model.srctest.SrcTest">
    <id column="id" jdbcType="INTEGER" property="id" />
    <result column="name" jdbcType="VARCHAR" property="name" />
    <result column="age" jdbcType="INTEGER" property="age" />
    <result column="ctime" jdbcType="BIGINT" property="ctime" />
  </resultMap>
<!-- 省略....-->
</mapper>
SrcTestMapperExt.xml
    <select id="selectExtTest" resultMap="BaseResultMap">
        select * from src_test where age>#{age}
    </select>
</mapper>
注意:这里返回的resultMap=“BaseResultMap” 这个Map并没有再这个xml中定义,这样能使用吗?
上面是我生成的代码;并且能够正常使用;
那么SrcTestMapperExt.xml是如何继承SrcTestMapper.xml中的定义的呢?
1. 修改命名空间,使他们的命名空间相同,namespace=“com.test.dao.mapper.srctest.SrcTestMapperExt”
2. 光这样还不够,因为这个时候你去运行的时候会报错
Caused by: org.apache.ibatis.builder.BuilderException: Wrong namespace. Expected 'com.test.dao.mapper.srctest.SrcTestMapper' but found 'com.test.dao.mapper.srctest.SrcTestMapperExt'.
因为Mybatis中是必须要 xml的文件包名和文件名必须跟 Mapper.java对应起来的
比如com.test.dao.mapper.srctest.SrcTestMapper.java这个相对应的是
com.test.dao.mapper.srctest.SrcTestMapper.xml
必须是这样子,没有例外,否则就会报错
show the code
MapperBuilderAssistant
  public void setCurrentNamespace(String currentNamespace) {
    if (currentNamespace == null) {
      throw new BuilderException("The mapper element requires a namespace attribute to be specified.");
    if (this.currentNamespace != null && !this.currentNamespace.equals(currentNamespace)) {
      throw new BuilderException("Wrong namespace. Expected '"
          + this.currentNamespace + "' but found '" + currentNamespace + "'.");
    this.currentNamespace = currentNamespace;
这个this.currentNamespace 和参数传进来的currentNamespace比较是否相等;
参数传进来的currentNamespace就是我们xml中的
<mapper namespace="com.test.dao.mapper.srctest.SrcTestMapperExt">值;
然后this.currentNamespace是从哪里设置的呢?this.currentNamespace = currentNamespace;
跟下代码:MapperAnnotationBuilder
  public void parse() {
    String resource = type.toString();
    if (!configuration.isResourceLoaded(resource)) {
      loadXmlResource();
      configuration.addLoadedResource(resource);
      assistant.setCurrentNamespace(type.getName());
      parseCache();
      parseCacheRef();
      Method[] methods = type.getMethods();
      for (Method method : methods) {
        try {
          // issue #237
          if (!method.isBridge()) {
            parseStatement(method);
        } catch (IncompleteElementException e) {
          configuration.addIncompleteMethod(new MethodResolver(this, method));
    parsePendingMethods();
看到 assistant.setCurrentNamespace(type.getName());
它获取的是 type.getName() ;这个type的最终来源是
MapperFactoryBean<T>
  @Override
  protected void checkDaoConfig() {
    super.checkDaoConfig();
    notNull(this.mapperInterface, "Property 'mapperInterface' is required");
    Configuration configuration = getSqlSession().getConfiguration();
    if (this.addToConfig && !configuration.hasMapper(this.mapperInterface)) {
      try {
        configuration.addMapper(this.mapperInterface);
      } catch (Exception e) {
        logger.error("Error while adding the mapper '" + this.mapperInterface + "' to configuration.", e);
        throw new IllegalArgumentException(e);
      } finally {
        ErrorContext.instance().reset();
configuration.addMapper(this.mapperInterface);这行应该就明白了
加载mapperInterface的时候会跟相应的xml映射,并且会去检验namespace是否跟mapperInterface相等!
那么既然命名空间不能修改,那第一条不白说了?还怎么实现Mapper.xml的继承啊?
别慌,既然是这样子,那我们可以让 MapperInterface 中的SrcTestMapper.java别被加载进来就行了啊!!
只加载 MapperExt.java不就行了?
3. 修改applicationContext.xml,让Mapper.java不被扫描
Mapper.java接口扫描配置
    <!-- Mapper接口所在包名,Spring会自动查找其下的Mapper -->
    <bean id="mapperScannerConfigurer" class="org.mybatis.spring.mapper.MapperScannerConfigurer">
        <property name="basePackage" value="com.test.dao.mapper"/>
        该属性实际上就是起到一个过滤的作用,如果设置了该属性,那么MyBatis的接口只有包含该注解,才会被扫描进去。
        <property name="annotationClass" value="javax.annotation.Resource"/>
        <property name="sqlSessionFactoryBeanName" value="sqlSessionFactory"/>
    </bean>
basePackage 把Mapper.java扫描进去没有关系,重点是
这样 MapperScanner会把没有配置注解的过滤掉;
回头看我们的MapperExt.java配置文件是有加上注解的
@Resource
这样子之后,基本上问题就解决了,还有一个地方特别要注意一下的是.xml文件的配置
    <bean id="sqlSessionFactory" class="org.mybatis.spring.SqlSessionFactoryBean">
        <property name="dataSource" ref="dataSource"/>
        <property name="configLocation" value="classpath:mybatis-config.xml"/>
        <!-- 必须将mapper,和mapperExt也一起扫描-->
        <property name="mapperLocations" value="classpath:com/test/dao/mapper/**/*.xml"/>
    </bean>
这样配置没有错,但是我之前的配置写成了
<property name="mapperLocations" value="classpath:com/test/dao/mapper/**/*Mapper.xml"/>
这样子 MapperExt.xml 没有被扫描进去,在我执行单元测试的时候
  @Test
    public void selectExt(){
        List<SrcTest> tests = srcTestService.selectExtTest(9);
        System.out.println(tests.toString());
err_console
org.apache.ibatis.binding.BindingException: Invalid bound statement (not found): com.test.dao.mapper.srctest.SrcTestMapperExt.selectExtTest
但是执行srcTestService.insertSelective(srcTest);不会出错
原因就是 insertSelective是在SrcTestMapper.xml中存在 ,已经被注册到
com.test.dao.mapper.srctest.SrcTestMapperExt命名空间了,但是selectExtTest由于没有被注册,所以报错了;
有兴趣可以下载阅读或者直接使用我整合的
自动生成扩展插件
评论(0
