Mysql查询详解(条件查询、子查询、模糊查询、连接查询等)丨【绽放吧!数据库】
Code皮皮虾 发表于 2021/07/21 14:06:01 2021/07/21
【摘要】 Mysql查询详解(条件查询、子查询、模糊查询、连接查询等)丨【绽放吧!数据库】
Mysql练习题,可对本章学习的内容进行巩固
一、创建数据库和数据表
dept.sql
部门表
SET NAMES utf8mb4;
SET FOREIGN_KEY_CHECKS = 0;
-- Table structure for dept
DROP TABLE IF EXISTS `dept`;
CREATE TABLE `dept`  (
  `DEPTNO` int(2) NOT NULL,
  `DNAME` varchar(14) CHARACTER SET utf8 COLLATE utf8_general_ci NULL DEFAULT NULL,
  `LOC` varchar(13) CHARACTER SET utf8 COLLATE utf8_general_ci NULL DEFAULT NULL,
  PRIMARY KEY (`DEPTNO`) USING BTREE
) ENGINE = InnoDB CHARACTER SET = utf8 COLLATE = utf8_general_ci ROW_FORMAT = Dynamic;
-- Records of dept
INSERT INTO `dept` VALUES (10, 'ACCOUNTING', 'NEW YORK');
INSERT INTO `dept` VALUES (20, 'RESEARCH', 'DALLAS');
INSERT INTO `dept` VALUES (30, 'SALES', 'CHICAGO');
INSERT INTO `dept` VALUES (40, 'OPERATIONS', 'BOSTON');
SET FOREIGN_KEY_CHECKS = 1;
emp.sql
员工表
SET NAMES utf8mb4;
-- Table structure for emp
DROP TABLE IF EXISTS `emp`;
CREATE TABLE `emp`  (
  `EMPNO` int(4) NOT NULL,
  `ENAME` varchar(10) CHARACTER SET utf8 COLLATE utf8_general_ci NULL DEFAULT NULL,
  `JOB` varchar(9) CHARACTER SET utf8 COLLATE utf8_general_ci NULL DEFAULT NULL,
  `MGR` int(4) NULL DEFAULT NULL,
  `HIREDATE` date NULL DEFAULT NULL,
  `SAL` double(7, 2) NULL DEFAULT NULL,
  `COMM` double(7, 2) NULL DEFAULT NULL,
  `DEPTNO` int(2) NULL DEFAULT NULL,
  PRIMARY KEY (`EMPNO`) USING BTREE
-- Records of emp
INSERT INTO `emp` VALUES (7369, 'SMITH', 'CLERK', 7902, '1980-12-17', 800.00, NULL, 20);
INSERT INTO `emp` VALUES (7499, 'ALLEN', 'SALESMAN', 7698, '1981-02-20', 1600.00, 300.00, 30);
INSERT INTO `emp` VALUES (7521, 'WARD', 'SALESMAN', 7698, '1981-02-22', 1250.00, 500.00, 30);
INSERT INTO `emp` VALUES (7566, 'JONES', 'MANAGER', 7839, '1981-04-02', 2975.00, NULL, 20);
INSERT INTO `emp` VALUES (7654, 'MARTIN', 'SALESMAN', 7698, '1981-09-28', 1250.00, 1400.00, 30);
INSERT INTO `emp` VALUES (7698, 'BLAKE', 'MANAGER', 7839, '1981-05-01', 2850.00, NULL, 30);
INSERT INTO `emp` VALUES (7782, 'CLARK', 'MANAGER', 7839, '1981-06-09', 2450.00, NULL, 10);
INSERT INTO `emp` VALUES (7788, 'SCOTT', 'ANALYST', 7566, '1987-04-19', 3000.00, NULL, 20);
INSERT INTO `emp` VALUES (7839, 'KING', 'PRESIDENT', NULL, '1981-11-17', 5000.00, NULL, 10);
INSERT INTO `emp` VALUES (7844, 'TURNER', 'SALESMAN', 7698, '1981-09-08', 1500.00, 0.00, 30);
INSERT INTO `emp` VALUES (7876, 'ADAMS', 'CLERK', 7788, '1987-05-23', 1100.00, NULL, 20);
INSERT INTO `emp` VALUES (7900, 'JAMES', 'CLERK', 7698, '1981-12-03', 950.00, NULL, 30);
INSERT INTO `emp` VALUES (7902, 'FORD', 'ANALYST', 7566, '1981-12-03', 3000.00, NULL, 20);
INSERT INTO `emp` VALUES (7934, 'MILLER', 'CLERK', 7782, '1982-01-23', 1300.00, NULL, 10);
salgrade.sql
等级划分表
SET NAMES utf8mb4;
-- Table structure for salgrade
DROP TABLE IF EXISTS `salgrade`;
CREATE TABLE `salgrade`  (
  `GRADE` int(11) NULL DEFAULT NULL,
  `LOSAL` int(11) NULL DEFAULT NULL,
  `HISAL` int(11) NULL DEFAULT NULL
-- Records of salgrade
INSERT INTO `salgrade` VALUES (1, 700, 1200);
INSERT INTO `salgrade` VALUES (2, 1201, 1400);
INSERT INTO `salgrade` VALUES (3, 1401, 2000);
INSERT INTO `salgrade` VALUES (4, 2001, 3000);
INSERT INTO `salgrade` VALUES (5, 3001, 9999);
二、简单查询
语法格式:==select 字段1,字段2,字段3,… from 表名;==
查询每个员工的工资
SELECT ename,sal from emp;
给查询列起别名
SELECT ename,sal as '工资' from emp;
注意:字符串要使用单引号括起来,尽量别使用双引号
三、条件查询
条件查询需要用到where语句,where语句必须放到from语句后面。
==语法格式如下==
select
	字段,字段...
from
	表名
where
	条件;
==条件查询支持以下运算符==
运算符 说明
= 等于
<>或 != 不等于
< 小于
> 大于
<= 小于等于
>= 大于等于
between … and 两个值之间,等同于 >= and <=
is null 为null
and 并且
or 或者
in 包含,相当于多个or(not in 则是不在这个范围中)
not not 可以取非,主要用在 is 或 in 中
like like 称为模糊查询,支持%或下划线匹配
==查询工资为5000的员工姓名==
select
	ename,sal
from
	emp
where
	sal = 5000;
==查询工资小于3000的员工姓名==
select
	ename,sal
from
	emp
where
	sal < 3000;
其余可参考之前的表格,这里我不做过多演示。
条件查询between and
between and 在使用的时候必须是左小右大
select
	ename,sal
from
	emp
where
	sal between 2000 and 3000;
between and 还可以使用在字符串方面(左为闭区间,右为开区间)
select
	ename
from
	emp
where
	ename between 'A' and 'C';
条件查询 is null 、is not null
在数据库当中NULL不是一个值,代表什么也没有,为空。空不是一个值,不能用等号判断,必须使用 is null 或 is not null 进行判断。
查询comm为null的数据
select
	ename,comm
from
	emp
where
	comm is null;
查询comm为不为null的数据
select
	ename,comm
from
	emp
where
	comm is not null;
条件查询 in
select
	ename,sal
from
	emp
where
	sal in(3000,5000);
in:sal值为3000和5000的数据
select
	ename,sal
from
	emp
where
	sal not in(3000,5000);
not in:sal不在(3000,5000)这几个值中
四、模糊查询
==搭配%使用==
%代表一个或多个字符的通配符
(1)
select
	ename,sal
from
	emp
where
	ename like '%S%';
ename like ‘%S%’; 名称中带有S的名字
select
	ename,sal
from
	emp
where
	ename like 'S%';
查询名称中开始字符为S的数据
select
	ename,sal
from
	emp
where
	ename like '%S';
插叙名称中最后一个字符为S的数据
==搭配_使用==
_代表仅仅一个字符的通配符
select
	ename,sal
from
	emp
where
	ename like 'KIN_';
五、分组查询
group by :按照某个字段或者某些字段进行分组
having:having是对分组之后的数据进行再次过滤。
select
	AVG(sal),deptno
from
	emp
group by
	deptno;
select
	deptno
from
	emp
group by
	deptno
having
	deptno >= 20;
==注意事项==
  • GROUP BY后不可以接列的别名
  • GROUP BY 后不能接数字
  • GROUP BY 后不可以接select后没有的列名
  • 如果一个SELECT中使用了分组函数,任何不在分组函数中的列(表达式)必须要在GROUP BY中
六、连接查询
在使用数据库查询语句时,单表的查询有时候不能满足项目的业务需求,在项目开发过程中,有很多需求都是要涉及到多表的连接查询
==连接查询分类==
  • 内连接
    • 等值连接
    • 非等值连接
    • 自连接
  • 外连接
    • 左外连接(左连接)
    • 右外连接 (右连接)
  • 全连接
内连接
等值连接
特点:条件是等量关系
查询每个员工的部门名称,要求显示员工名和部门名
select
	e.ename,d.dname
from
	emp e
join
	dept d
on
	e.deptno = d.deptno;
非等值连接
特点:连接条件是非等量关系
找出每个员工的工资等级,要求显示员工名、工资、工资等级
select
	e.ename,e.sal,s.grade
from
	emp e
join
	salgrade s
on
	e.sal between s.losal and s.hisal;
自连接
特点:一张表当成两张表。自己连接自己
找出每个员工的上级领导,要求显示员工名和对应的领导名称
select
	e.ename,m.ename
from
	emp e
left join
	emp m
on
	e.mgr = m.empno;
外连接
假设A和B表进行连接,使用外连接的话,AB两张表中有一张表是主表,一张表是副表,主要查询主表中的数据,捎带着查询副表,当副表中的数据没有和主表中的数据匹配上,副表自动模拟出NULL与之匹配。
外连接分类
  • 左外连接(左连接):表示左边的这张表是主表。
  • 右外连接(右连接):表示右边的这张表是主表。
#基本语法
左表 left/right join 右表 on 左表.字段=右表.字段
七、子查询
==1、where后面嵌套子查询==
select
	ename,sal
from
	emp
where
	sal > (select avg(sal) from emp);
==2、from后面嵌套子查询==
列出各种工作的最低工资及从事此工作的雇员姓名
select
	e.ename,t.*
from
	emp e
join
	(select job,min(sal) as minsal from emp group by job) t
on
	e.job=t.job and e.sal=t.minsal;
==3、select后面嵌套子查询==
查询每个员工所在部门名称
select
	e.ename,d.dname,
	(select d.dname from dept d where e.deptno = d.deptno) as dname
from
	emp e;
觉得不错的小伙伴可以点赞关注和收藏哦!如有错误可以指出来。
【绽放吧!数据库】有奖征文火热进行中 https://bbs.huaweicloud.cn/blogs/285617
