【小白学习keras教程】九、keras 使用GPU和Callbacks模型保存
毛利 发表于 2021/07/16 20:57:58 2021/07/16
【摘要】 @Author:Runsen GPU在gpu上训练使训练神经网络比在cpu上运行快得多Keras支持使用Tensorflow和Theano后端对gpu进行培训文档: https://keras.io/getting-started/faq/#how-can-i-run-keras-on-gpu 安装GPU首先,下载并安装CUDA&CuDNN(假设您使用的是NVIDIA gpu)安装url...
@Author:Runsen
GPU
  • 在gpu上训练使训练神经网络比在cpu上运行快得多
  • Keras支持使用Tensorflow和Theano后端对gpu进行培训
安装GPU
  • 首先,下载并安装CUDA&CuDNN(假设您使用的是NVIDIA gpu)
  • 安装url: https://developer.nvidia.com/cudnn
  • 然后,通过在cmd或terminal中键入以下命令来安装tensorflow gpu(启用gpu的tensorflow版本)
  • pip install tensorflow gpu
  • 然后检查机器正在使用GPU设备
  • 在下面例子中,我有一个GPU设备(其名称为“/device:GPU:0”)
  • 如果使用的是Google Colab,只需将运行时类型更改为“GPU”
import tensorflow as tf
from tensorflow.python.client import device_lib
device_lib.list_local_devices()
Keras Callbacks
Keras Callbacks 为模型训练过程提供了有用的工具
  • ModelCheckpoint
  • Earlystopping
  • ReduceLROnPlateau
from sklearn.datasets import load_digits
from sklearn.model_selection import train_test_split
from tensorflow.keras.models import Sequential
from tensorflow.keras.utils import to_categorical
from tensorflow.keras import optimizers
from tensorflow.keras.callbacks import *
from tensorflow.keras.layers import *
data = load_digits()
X_data = data.images
y_data = data.target
X_train, X_test, y_train, y_test = train_test_split(X_data, y_data, test_size = 0.3, random_state = 777)
# reshaping X data => flatten into 1-dimensional
X_train = X_train.reshape((X_train.shape[0], -1))
X_test = X_test.reshape((X_test.shape[0], -1))
# converting y data into categorical (one-hot encoding)
y_train = to_categorical(y_train)
y_test = to_categorical(y_test)
1. ModelCheckpoint
  • ModelCheckpoint用于对训练结果进行“检查点”建模
  • 通常,它仅用于保存最佳模型
def create_model():
    model = Sequential()
    model.add(Dense(100, input_shape = (X_train.shape[1],)))
    model.add(Activation('relu'))
    model.add(Dense(100))
    model.add(Dense(y_train.shape[1]))
    model.add(Activation('sigmoid'))
    model.compile(optimizer = 'Adam', loss = 'categorical_crossentropy', metrics = ['accuracy'])
    return model
model = create_model()
Creating callbacks list
  • ModelCheckpoint实例存储在列表中,并在训练时传递
callbacks = [ModelCheckpoint(filepath = 'saved_model.hdf5', monitor='val_acc', verbose=1, mode='max')]
model.fit(X_train, y_train, epochs = 10, batch_size = 500, callbacks = callbacks, validation_data = (X_test, y_test))
Loading saved weights
  • 保存的重量可以加载和使用,而无需进一步训练
  • 当训练时间很长并且模型需要多次重用时,这一点尤其有用
another_model = create_model()
another_model.load_weights('saved_model.hdf5')
another_model.compile(optimizer = 'Adam', loss = 'categorical_crossentropy', metrics = ['accuracy'])
Selecting best model
  • 可以使用ModelCheckpoint选择整个epoch中的最佳模型
  • 将**‘save_best_only’**参数设置为True
  • 通常,验证准确度(val acc)被监控并用作最佳模型的标准
callbacks = [ModelCheckpoint(filepath = 'best_model.hdf5', monitor='val_accuracy', verbose=1, save_best_only = True, mode='max')]
best_model = create_model()
best_model.load_weights('best_model.hdf5')
best_model.compile(optimizer = 'Adam', loss = 'categorical_crossentropy', metrics = ['accuracy'])
results = best_model.evaluate(X_test, y_test)
print('Accuracy: ', results[1])
Accuracy: 0.9740740656852722
2.Early stopping
  • 我们可以设置patience参数,它表示模型在没有任何改进的情况下将停下训练
callbacks = [EarlyStopping(monitor = 'accuracy', patience = 1)]
model.fit(X_train, y_train, epochs = 20, batch_size = 500, callbacks = callbacks, validation_data = (X_test, y_test))
3.Reduce learning rate
  • 一般来说,随着训练的进行,降低学习率(学习率衰减)是可取的
callbacks = [ReduceLROnPlateau(monitor = 'val_loss', factor = 0.5, patience = 5)]
results = model.evaluate(X_test, y_test)
Accuracy: 0.949999988079071
评论(0
