leetcode刷题 60 61
毛利 发表于 2021/07/15 22:24:30 2021/07/15
【摘要】 官方题解 import math class Solution: def getPermutation(self, n: int, k: int) -> str: nums = list(range(1,n+1)) out = '' while n>1: temp = math.factorial(n-1) #print(k,temp) pos...
官方题解
import math
class Solution: def getPermutation(self, n: int, k: int) -> str: nums = list(range(1,n+1)) out = '' while n>1: temp = math.factorial(n-1) #print(k,temp) pos = (k-1)//temp k = k%temp nn = nums[pos] out += str(nn) nums.remove(nn) n -= 1 return out+str(nums[-1])
官方题解
class Solution: def rotateRight(self, head: ListNode, k: int) -> ListNode: if not head: return None p=q=head l=1 while p.next: p=p.next l+=1 p.next=head k%=l for _ in range(l-k-1): q=q.next ans=q.next q.next=None return ans
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90450746
