回归:预测燃油效率
毛利 发表于 2021/07/15 07:43:23 2021/07/15
【摘要】 回归:预测燃油效率 在一个回归问题中,我们的目标是预测一个连续值的输出,比如价格或概率。这与一个分类问题形成对比,我们的目标是从一系列类中选择一个类(例如,一张图片包含一个苹果或一个橘子,识别图片中的水果)。 本笔记本使用经典的[auto-mpg](https://archive.ics.uci.edu/ml/datasets/auto+mpg)数据集,建立了预...
回归:预测燃油效率
本笔记本使用经典的[auto-mpg](https://archive.ics.uci.edu/ml/datasets/auto+mpg)数据集,建立了预测70年代末和80年代初汽车燃油效率的模型。为了做到这一点,我们将为该模型提供从那个时期开始的许多汽车的描述。此描述包括以下属性:气缸、排量、马力和重量。
此示例使用“tf.keras”API,有关详细信息,请参阅[本指南](https://www.tensorflow.org/guide/keras)。
import pathlib
import pandas as pd
import seaborn as sns
import keras
from keras import layers
%matplotlib inline
The Auto MPG dataset
The dataset is available from the UCI Machine Learning Repository.
Get the data
First download the dataset.
dataset_path = keras.utils.get_file("auto-mpg.data", "https://archive.ics.uci.edu/ml/machine-learning-databases/auto-mpg/auto-mpg.data")
dataset_path
'C:\\Users\\YIUYE\\.keras\\datasets\\auto-mpg.data'
Import it using pandas
column_names = ['MPG','Cylinders','Displacement','Horsepower','Weight', 'Acceleration', 'Model Year', 'Origin']
raw_dataset = pd.read_csv(dataset_path, names=column_names, na_values = "?", comment='\t', sep=" ", skipinitialspace=True)
dataset = raw_dataset.copy()
dataset.tail()
MPG Cylinders Displacement Horsepower Weight Acceleration Model Year Origin
393 27.0 4 140.0 86.0 2790.0 15.6 82 1
394 44.0 4 97.0 52.0 2130.0 24.6 82 2
395 32.0 4 135.0 84.0 2295.0 11.6 82 1
396 28.0 4 120.0 79.0 2625.0 18.6 82 1
397 31.0 4 119.0 82.0 2720.0 19.4 82 1
Clean the data
The dataset contains a few unknown values.
dataset.isnull().sum()
MPG 0
Cylinders 0
Displacement 0
Horsepower 6
Weight 0
Acceleration 0
Model Year 0
Origin 0
dtype: int64
To keep this initial tutorial simple drop those rows.
dataset = dataset.dropna()
The "Origin" column is really categorical, not numeric. So convert that to a one-hot:
origin = dataset.pop('Origin')
dataset['USA'] = (origin == 1)*1.0
dataset['Europe'] = (origin == 2)*1.0
dataset['Japan'] = (origin == 3)*1.0
dataset.tail()
MPG Cylinders Displacement Horsepower Weight Acceleration Model Year USA Europe Japan
393 27.0 4 140.0 86.0 2790.0 15.6 82 1.0 0.0 0.0
394 44.0 4 97.0 52.0 2130.0 24.6 82 0.0 1.0 0.0
395 32.0 4 135.0 84.0 2295.0 11.6 82 1.0 0.0 0.0
396 28.0 4 120.0 79.0 2625.0 18.6 82 1.0 0.0 0.0
397 31.0 4 119.0 82.0 2720.0 19.4 82 1.0 0.0 0.0
现在将数据集拆分为一个训练集和一个测试集。
我们将在模型的最终评估中使用测试集。
train_dataset = dataset.sample(frac=0.8,random_state=0)
test_dataset = dataset.drop(train_dataset.index)
sns.pairplot(train_dataset[[ "Cylinders", "Displacement", "Weight"]], diag_kind="kde")
sns.set()
Also look at the overall statistics:
train_stats = train_dataset.describe()
train_stats.pop("MPG")
train_stats = train_stats.transpose()
train_stats
count mean std min 25% 50% 75% max
Cylinders 314.0 5.477707 1.699788 3.0 4.00 4.0 8.00 8.0
Displacement 314.0 195.318471 104.331589 68.0 105.50 151.0 265.75 455.0
Horsepower 314.0 104.869427 38.096214 46.0 76.25 94.5 128.00 225.0
Weight 314.0 2990.251592 843.898596 1649.0 2256.50 2822.5 3608.00 5140.0
Acceleration 314.0 15.559236 2.789230 8.0 13.80 15.5 17.20 24.8
Model Year 314.0 75.898089 3.675642 70.0 73.00 76.0 79.00 82.0
USA 314.0 0.624204 0.485101 0.0 0.00 1.0 1.00 1.0
Europe 314.0 0.178344 0.383413 0.0 0.00 0.0 0.00 1.0
Japan 314.0 0.197452 0.398712 0.0 0.00 0.0 0.00 1.0
Split features from labels
Separate the target value, or “label”, from the features. This label is the value that you will train the model to predict.
train_labels = train_dataset.pop('MPG')
test_labels = test_dataset.pop('MPG')
Normalize the data
Look again at the train_stats block above and note how different the ranges of each feature are.
规范化使用不同尺度和范围的特征是一个很好的实践。虽然模型可能在没有特征规范化的情况下收敛,但它使训练变得更加困难,并且使生成的模型依赖于输入中使用的单元的选择。
注意:尽管我们有意只从训练数据集生成这些统计信息,但这些统计信息也将用于规范化测试数据集。我们需要这样做,以将测试数据集投影到模型所训练的相同分发中。
def norm(x):
  return (x - train_stats['mean']) / train_stats['std']
normed_train_data = norm(train_dataset)
normed_test_data = norm(test_dataset)
def build_model():
  model = keras.Sequential([ layers.Dense(64, activation=tf.nn.relu, input_shape=[len(train_dataset.keys())]), layers.Dense(64, activation=tf.nn.relu), layers.Dense(1)
  ]) optimizer = keras.optimizers.RMSprop(0.001) model.compile(loss='mean_squared_error', optimizer=optimizer, metrics=['mean_absolute_error', 'mean_squared_error'])
  return model
model = build_model()
model.summary()
_________________________________________________________________
Layer (type) Output Shape Param # =================================================================
dense_10 (Dense) (None, 64) 640 _________________________________________________________________
dense_11 (Dense) (None, 64) 4160 _________________________________________________________________
dense_12 (Dense) (None, 1) 65 =================================================================
Total params: 4,865
Trainable params: 4,865
Non-trainable params: 0
Now try out the model. Take a batch of 10 examples from the training data and call model.predict on it.
example_batch = normed_train_data[:10]
example_result = model.predict(example_batch)
example_result
array([[-0.03468257], [-0.01342154], [-0.15384783], [-0.18010283], [ 0.03922582], [-0.12172151], [ 0.10603201], [ 0.2442987 ], [ 0.00099315], [ 0.18530795]], dtype=float32)
It seems to be working, and it produces a result of the expected shape and type.
Train the model
Train the model for 1000 epochs, and record the training and validation accuracy in the history object.
# Display training progress by printing a single dot for each completed epoch
class PrintDot(keras.callbacks.Callback):
  def on_epoch_end(self, epoch, logs): if epoch % 100 == 0: print('') print('.', end='')
EPOCHS = 1000
history = model.fit(
  normed_train_data, train_labels,
  epochs=EPOCHS, validation_split = 0.2, verbose=0,
  callbacks=[PrintDot()])
hist = pd.DataFrame(history.history)
hist['epoch'] = history.epoch
hist.tail()
loss mean_absolute_error mean_squared_error val_loss val_mean_absolute_error val_mean_squared_error epoch
995 2.075518 0.940943 2.075518 8.913726 2.351839 8.913726 995
996 2.130111 0.953561 2.130111 9.769884 2.438282 9.769884 996
997 2.221040 0.951258 2.221040 9.664708 2.382888 9.664708 997
998 2.301870 0.980407 2.301870 9.934311 2.425505 9.934311 998
999 2.002580 0.887644 2.002580 9.484982 2.414742 9.484982 999
def plot_history(history):
  hist['epoch'] = history.epoch plt.figure()
  plt.xlabel('Epoch')
  plt.ylabel('Mean Abs Error [MPG]')
  plt.plot(hist['epoch'], hist['mean_absolute_error'], label='Train Error')
  plt.plot(hist['epoch'], hist['val_mean_absolute_error'], label = 'Val Error')
  plt.ylim([0,5])
  plt.legend() plt.figure()
  plt.xlabel('Epoch')
  plt.ylabel('Mean Square Error [$MPG^2$]')
  plt.plot(hist['epoch'], hist['mean_squared_error'], label='Train Error')
  plt.plot(hist['epoch'], hist['val_mean_squared_error'], label = 'Val Error')
  plt.ylim([0,20])
  plt.legend()
  plt.show()
  • 26
  • 27
此图显示在大约100个周期后,验证错误几乎没有改善,甚至恶化。让我们更新“model.fit”调用,以便在验证分数没有提高时自动停止培训。我们将使用一个早期的回调来测试每个时代的训练条件。如果一个设定的时间段没有显示出改善,那么自动停止训练。
# The patience parameter is the amount of epochs to check for improvement
early_stop = keras.callbacks.EarlyStopping(monitor='val_loss', patience=10)
history = model.fit(normed_train_data, train_labels, epochs=EPOCHS, validation_split = 0.2, verbose=0, callbacks=[early_stop, PrintDot()])
loss, mae, mse = model.evaluate(normed_test_data, test_labels, verbose=0)
print("Testing set Mean Abs Error: {:5.2f} MPG".format(mae))
Testing set Mean Abs Error:  1.79 MPG
Make predictions
Finally, predict MPG values using data in the testing set:
test_predictions = model.predict(normed_test_data).flatten()
plt.scatter(test_labels, test_predictions)
plt.xlabel('True Values [MPG]')
plt.ylabel('Predictions [MPG]')
plt.axis('equal')
plt.axis('square')
plt.xlim([0,plt.xlim()[1]])
plt.ylim([0,plt.ylim()[1]])
_ = plt.plot([-100, 100], [-100, 100])
error = test_predictions - test_labels
plt.hist(error, bins = 25)
plt.xlabel("Prediction Error [MPG]")
_ = plt.ylabel("Count")
它不是很高斯的,但是我们可以预期,因为样本的数量非常小。
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/89441202
