汽车购买分类
毛利 发表于 2021/07/15 07:54:10 2021/07/15
【摘要】 原数据 根据 ‘buy’, ‘maintain’, ‘doors’, ‘persons’, ‘boot’, ‘safety’, ‘accept’ 购买”、“维护”、“门”、“人”、“系统”、“安全” 来判断顾客是否接受买车 # -*- coding:utf-8 -*- import pandas as pd import numpy as np from sk...
原数据
import pandas as pd
import numpy as np
from sklearn.linear_model import LogisticRegressionCV
from sklearn import metrics
from sklearn.model_selection import train_test_split
from sklearn.preprocessing import label_binarize
import matplotlib as mpl
from sklearn.ensemble import RandomForestClassifier
if __name__ == '__main__': pd.set_option('display.width', 300) pd.set_option('display.max_columns', 300) data = pd.read_csv('car.data', header=None) n_columns = len(data.columns) columns = ['buy', 'maintain', 'doors', 'persons', 'boot', 'safety', 'accept'] new_columns = dict(list(zip(np.arange(n_columns), columns))) data.rename(columns=new_columns, inplace=True) print(data.head(10)) # one-hot编码 x = pd.DataFrame() for col in columns[:-1]: t = pd.get_dummies(data[col]) t = t.rename(columns=lambda x: col+'_'+str(x)) x = pd.concat((x, t), axis=1) print(x.head(10)) print(x.shape) y = np.array(pd.Categorical(data['accept']).codes) x, x_test, y, y_test = train_test_split(x, y, test_size=0.3) clf = LogisticRegressionCV(Cs=np.logspace(-3, 4, 8), cv=5) # clf = RandomForestClassifier(n_estimators=50, max_depth=7) clf.fit(x, y) y_hat = clf.predict(x) print('训练集精确度:', metrics.accuracy_score(y, y_hat)) y_test_hat = clf.predict(x_test) print('测试集精确度:', metrics.accuracy_score(y_test, y_test_hat)) n_class = len(np.unique(y)) if n_class > 2: y_test_one_hot = label_binarize(y_test, classes=np.arange(n_class)) y_test_one_hot_hat = clf.predict_proba(x_test) fpr, tpr, _ = metrics.roc_curve(y_test_one_hot.ravel(), y_test_one_hot_hat.ravel()) print('Micro AUC:\t', metrics.auc(fpr, tpr)) auc = metrics.roc_auc_score(y_test_one_hot, y_test_one_hot_hat, average='micro') print('Micro AUC(System):\t', auc) auc = metrics.roc_auc_score(y_test_one_hot, y_test_one_hot_hat, average='macro') print('Macro AUC:\t', auc) else: fpr, tpr, _ = metrics.roc_curve(y_test.ravel(), y_test_hat.ravel()) print('AUC:\t', metrics.auc(fpr, tpr)) auc = metrics.roc_auc_score(y_test, y_test_hat) print('AUC(System):\t', auc) mpl.rcParams['font.sans-serif'] = 'SimHei' mpl.rcParams['axes.unicode_minus'] = False plt.figure(figsize=(8, 7), facecolor='w') plt.plot(fpr, tpr, 'r-', lw=2, label='AUC=%.4f' % auc) plt.legend(loc='lower right', fontsize=14) plt.xlim((-0.01, 1.02)) plt.ylim((-0.01, 1.02)) plt.xticks(np.arange(0, 1.1, 0.1)) plt.yticks(np.arange(0, 1.1, 0.1)) plt.xlabel('False Positive Rate', fontsize=14) plt.ylabel('True Positive Rate', fontsize=14) plt.grid(b=True, ls=':') plt.title('ROC曲线和AUC', fontsize=16) plt.show()
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
y
独热编码:x的数据
   buy_high  buy_low  buy_med  buy_vhigh  maintain_high  maintain_low  maintain_med  maintain_vhigh  doors_2  doors_3  doors_4  doors_5more  persons_2  persons_4  persons_more  boot_big  boot_med  boot_small  safety_high  safety_low  safety_med
0 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 0 1 0 1 0
1 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 0 1 0 0 1
2 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 0 1 1 0 0
3 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 1 0 0 1 0
4 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 1 0 0 0 1
5 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 0 1 0 1 0 0
6 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 1 0 0 0 1 0
7 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 1 0 0 0 0 1
8 0 0 0 1 0 0 0 1 1 0 0 0 1 0 0 1 0 0 1 0 0
9 0 0 0 1 0 0 0 1 1 0 0 0 0 1 0 0 0 1 0 1 0
训练集精确度: 0.9081885856079405
测试集精确度: 0.8921001926782274
Micro AUC: 0.9834757073221438
Micro AUC(System): 0.9834757073221438
Macro AUC: 0.9668852150116471
训练集精确度: 0.9545078577336642
测试集精确度: 0.9075144508670521
Micro AUC: 0.9924203330598466
Micro AUC(System): 0.9924203330598466
Macro AUC: 0.988179483976249
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/89532213
