leetcode 刷题108109
毛利 发表于 2021/07/15 07:16:33 2021/07/15
【摘要】 # Definition for a binary tree node # class TreeNode: # def __init__(self, x): # self.val = x # self.left = None # self.right = None class Solution: def sortedArrayToBST(self, num)...
# class TreeNode:
# self.val = x
# self.left = None
# self.right = None
class Solution: def sortedArrayToBST(self, num): if not num: return None mid = len(num) // 2 root = TreeNode(num[mid]) root.left = self.sortedArrayToBST(num[:mid]) root.right = self.sortedArrayToBST(num[mid+1:]) return root
# Definition for singly-linked list.
# class ListNode:
# self.val = x
# self.next = None
# Definition for a binary tree node.
# class TreeNode:
# self.val = x
# self.left = None
# self.right = None
class Solution: def sortedListToBST(self,head): cnt = 0 copy = head while head is not None: cnt+=1 head = head.next return self.constructBST_fromList(copy,cnt)[0] def constructBST_fromList(self,begin,length): if length==0: return None,begin mid = length//2 left,cur = self.constructBST_fromList(begin,mid) node = TreeNode(cur.val) node.left = left right,cur = self.constructBST_fromList(cur.next,length-mid-1) node.right = right return node,cur
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
class Solution(object): def sortedListToBST(self, head): if not head: return if not head.next: return TreeNode(head.val) fast = head slow = None while fast and fast.next: fast = fast.next.next slow = head if slow is None else slow.next node = TreeNode(slow.next.val) tmp = slow.next.next slow.next = None node.left = self.sortedListToBST(head) node.right = self.sortedListToBST(tmp) return node
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90723458
