leetcode 刷题 138 139
毛利 发表于 2021/07/15 06:34:38 2021/07/15
【摘要】 """ # Definition for a Node. class Node: def __init__(self, val, next, random): self.val = val self.next = next self.random = random """ class Solution: def copyRandomList(self, head:...
class Solution: def copyRandomList(self, head: 'Node') -> 'Node': """ :type head: Node :rtype: Node """ if not head: return head d = {} p = h = Node(0,None,None) q = head while q: p.next = Node(q.val,None,None) p = p.next p.next = None d[q] = p q = q.next p,q = h.next,head while q: if q.random: p.random = d[q.random] p,q = p.next,q.next
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
class Solution(object): def copyRandomList(self, head): """ :type head: Node :rtype: Node """ if not head: return head cur = head while cur: node = Node(cur.val,None,None) node.next = cur.next cur.next = node cur = node.next cur = head while cur: if cur.random: cur.next.random = cur.random.next cur = cur.next.next cur = head res = head.next while cur: tmp = cur.next cur.next = tmp.next cur = cur.next if cur: tmp.next = cur.next return res
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
class Solution: def wordBreak(self, s: str, wordDict: List[str]) -> bool: starts = [0] for i in range(len(s)): for j in starts: if s[j:i+1] in wordDict: starts.append(i+1) break return starts[-1] == len(s)
class Solution: def wordBreak(self, s: str, wordDict: List[str]) -> bool: result, max_len = [0], 0 for each in wordDict: if len(each) > max_len: max_len = len(each) for i in range(1, len(s)+1): for j in result: if i-j <= max_len and s[j:i] in wordDict: result.append(i) break return result[-1] == len(s)
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90745201
