leetcode 刷题 73 74
毛利 发表于 2021/07/15 08:23:56 2021/07/15
【摘要】 class Solution: def setZeroes(self, matrix): # First row has zero? m, n, firstRowHasZero = len(matrix), len(matrix[0]), not all(matrix[0]) # Use first row/column as marker, scan the ...
class Solution: def setZeroes(self, matrix): # First row has zero? m, n, firstRowHasZero = len(matrix), len(matrix[0]), not all(matrix[0]) # Use first row/column as marker, scan the matrix for i in range(1, m): for j in range(n): if matrix[i][j] == 0: matrix[0][j] = matrix[i][0] = 0 # Set the zeros for i in range(1, m): for j in range(n - 1, -1, -1): if matrix[i][0] == 0 or matrix[0][j] == 0: matrix[i][j] = 0 # Set the zeros for the first row if firstRowHasZero: matrix[0] = [0] * n
和我想得一样直接遍历判断
二分查找
class Solution(object): def searchMatrix(self, matrix, target): """ :type matrix: List[List[int]] :type target: int :rtype: bool """ if(matrix == None or len(matrix) == 0 or len(matrix[0]) == 0): return False row = len(matrix) column = len(matrix[0]) i = row-1 j = 0 while i >= 0: if(matrix[i][0] > target): i = i-1 else: break while j+1 < column: if(matrix[i][j] < target): j = j+1 else: break if(matrix[i][j] == target): return True return False
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90525891
