kaggle机器学习作业(房价预测)
毛利 发表于 2021/07/15 08:49:00 2021/07/15
【摘要】 来源:kaggle Machine Learning Micro-Course Home Page Recap Here’s the code you’ve written so far. Start by running it again. # Code you have previously used to load data import pandas...
来源:kaggle
Recap
import pandas as pd
from sklearn.ensemble import RandomForestRegressor
from sklearn.metrics import mean_absolute_error
from sklearn.model_selection import train_test_split
from sklearn.tree import DecisionTreeRegressor # Path of the file to read. We changed the directory structure to simplify submitting to a competition
iowa_file_path = 'train.csv'
home_data = pd.read_csv(iowa_file_path)
# Create target object and call it y
y = home_data.SalePrice
# Create X
features = ['LotArea', 'YearBuilt', '1stFlrSF', '2ndFlrSF', 'FullBath', 'BedroomAbvGr', 'TotRmsAbvGrd']
X = home_data[features]
# Split into validation and training data
train_X, val_X, train_y, val_y = train_test_split(X, y, random_state=1)
# Specify Model
iowa_model = DecisionTreeRegressor(random_state=1)
# Fit Model
iowa_model.fit(train_X, train_y)
# Make validation predictions and calculate mean absolute error
val_predictions = iowa_model.predict(val_X)
val_mae = mean_absolute_error(val_predictions, val_y)
print("Validation MAE when not specifying max_leaf_nodes: {:,.0f}".format(val_mae))
# Using best value for max_leaf_nodes
iowa_model = DecisionTreeRegressor(max_leaf_nodes=100, random_state=1)
print("Validation MAE for best value of max_leaf_nodes: {:,.0f}".format(val_mae))
# Define the model. Set random_state to 1
rf_model = RandomForestRegressor(random_state=1)
rf_model.fit(train_X, train_y)
rf_val_predictions = rf_model.predict(val_X)
rf_val_mae = mean_absolute_error(rf_val_predictions, val_y)
print("Validation MAE for Random Forest Model: {:,.0f}".format(rf_val_mae))
Validation MAE when not specifying max_leaf_nodes: 29,653
Validation MAE for best value of max_leaf_nodes: 27,283
Validation MAE for Random Forest Model: 22,762
Creating a Model For the Competition
Build a Random Forest model and train it on all of X and y.
# To improve accuracy, create a new Random Forest model which you will train on all training data
rf_model_on_full_data = RandomForestRegressor(random_state=1)
# fit rf_model_on_full_data on all data from the training data
rf_model_on_full_data.fit(train_X,train_y)
RandomForestRegressor(bootstrap=True, criterion='mse', max_depth=None, max_features='auto', max_leaf_nodes=None, min_impurity_decrease=0.0, min_impurity_split=None, min_samples_leaf=1, min_samples_split=2, min_weight_fraction_leaf=0.0, n_estimators=10, n_jobs=None, oob_score=False, random_state=1, verbose=0, warm_start=False)
Make Predictions
Read the file of “test” data. And apply your model to make predictions
# path to file you will use for predictions
test_data_path = 'test.csv'
# read test data file using pandas
test_data = pd.read_csv(test_data_path)
# create test_X which comes from test_data but includes only the columns you used for prediction.
# The list of columns is stored in a variable called features
test_X = test_data[['LotArea', 'YearBuilt', '1stFlrSF', '2ndFlrSF', 'FullBath', 'BedroomAbvGr', 'TotRmsAbvGrd']]
# make predictions which we will submit.
test_preds = rf_model.predict(test_X)
# The lines below shows how to save predictions in format used for competition scoring
# Just uncomment them.
output = pd.DataFrame({'Id': test_data.Id, 'SalePrice': test_preds})
output.to_csv('submission.csv', index=False)
kaggle确实时一个不错的学习平台
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90548021
