leetcode刷题 83 84
毛利 发表于 2021/07/15 08:33:07 2021/07/15
【摘要】 from collections import deque class Solution: def largestRectangleArea(self, heights: List[int]) -> int: max_area = 0 stack = deque() for x in heights: ch = 1 while len(stack) &gt...
class Solution: def largestRectangleArea(self, heights: List[int]) -> int: max_area = 0 stack = deque() for x in heights: ch = 1 while len(stack) > 0 and x < stack[-1][0]: v, h = stack.pop() max_area = max(max_area, v*(h+ch-1)) ch += h stack.append([x, ch]) th = 0 while len(stack) > 0: v, h = stack.pop() th += h max_area = max(max_area, v*th) return max_area
class Solution(object): def largestRectangleArea(self, heights): heights.append(0) stackk = [] res = 0 for i in range(len(heights)): index = i while stackk and stackk[-1][1] > heights[i]: (index,height) = stackk.pop() res = max(res,height * (i-index)) stackk.append((index,heights[i])) return res
文章来源: maoli.blog.csdn.net,作者:刘润森!,版权归原作者所有,如需转载,请联系作者。
原文链接:maoli.blog.csdn.net/article/details/90551218
