ROS_RGB-D SLAM学习笔记--室内环境测试
zhangrelay 发表于 2021/07/15 07:21:49 2021/07/15
【摘要】 ROS_RGB-D SLAM学习笔记 RTAB-Map's ros-pkg. RTAB-Map is a RGB-D SLAM approach with real-time constraints. 先上英文参考: http://wiki.ros.org/rtabmap_ros indigo版源代码网址: https://github.com/intro...
ROS_RGB-D SLAM学习笔记
先上英文参考:
indigo版源代码网址:
https://github.com/introlab/rtabmap_ros/tree/indigo-devel
更为简单的安装方式:
$ sudo apt-get install ros-indigo-rtabmap*
测试,直接在终端输入:
$ rtabmap
具体操作过程可以参考视频:
http://v.youku.com/v_show/id_XMTQzOTU2MzQyNA
离线数据包视频:
http://v.youku.com/v_show/id_XMTQzOTU4MzY2NA
原文链接:zhangrelay.blog.csdn.net/article/details/50485437
