室内清扫机器人环境搭建与算法测试简易代码
zhangrelay 发表于 2021/07/15 05:47:51 2021/07/15
【摘要】 室内清扫机器人简易代码,由于时间紧张,地图构建和智能规划算法还没有研究, 给出已经完成的部分内容,抛砖引玉吧。 MazeBuilder //zhangrelay AddiRobotCreate ir1 /Position:0 0.1 0 /Procedure_Bumper_SensorNotify:wall1 / AddNewEntity en...
给出已经完成的部分内容,抛砖引玉吧。
MazeBuilder
//zhangrelay
AddNewEntity enthwf  	/Position:0  0.1  -0.1
	/Orientation:0 0 0
	/ParentEntity:ir1
AddBoxShape
	/Dimensions:0.001  0.001  0.001  	/Mass:0.01
AddInfraredRangeEntity hwf
	/ParentEntity:ir1
AddNewEntity enthwl  	/Position:-0.1  0.1  0
	/Orientation:0 90 0
	/ParentEntity:ir1
AddBoxShape
AddInfraredRangeEntity hwl
	/ParentEntity:enthwl
AddNewEntity enthwr  	/Position:0.1  0.1  0
	/Orientation:0 270 0
	/ParentEntity:ir1
AddBoxShape
AddInfraredRangeEntity hwr
	/ParentEntity:enthwr
//AddInfraredRangeEntity hwl
//	/Position:-0.3  0.2  0.0
//	/ParentEntity:ir1
//AddInfraredRangeEntity hwr
//	/Position:0.3  0.2  0.0
FlushScript
double iswall=0
double hwfd=0
double hwld=0
double hwrd=0
double SimTime=10000
double turnf=0
double turnfl=0
wait 40000
call proc_main  with concur
Procedure  proc_main
	call proc_robot_0
End
Procedure  wall1
// print value.Pressed. ToString() iswall=4
End
Procedure  proc_robot_0
	for (i = 0; i < SimTime; i++)
		hwfd=hwf.Get()
		hwrd=hwr.Get()
		hwld=hwl.Get()
//		print "f" + hwfd. ToString()
//		print "l" + hwld. ToString()
//		print "r" + hwrd. ToString()
		if(hwfd>0.4)
		{ iswall=0
		if(hwfd<0.2)
		{ if(turnfl==0) { turnf=1 } if(turnfl==1) { turnf=2 } if(turnfl==2) { turnf=1 } if(hwld<0.2) { turnf=3 } if(hwrd<0.2) { turnf=4 } if(turnfl==3) { if(turnf==3) { turnf=34 } } if(turnfl==4) { if(turnf==4) { turnf=44 } }
		if(iswall<1)
		{ ir1.Go(0.4)
//			ir1.Go(0) if(turnf==1) { ir1.Go(0) ir1.RotateDegrees(90, 0.4) hwfd=hwf.Get() if(hwfd>0.4) { ir1.GoTo(0.2, 0.4) } else { ir1.GoTo((hwfd-0.14), 0.2) } ir1.RotateDegrees(90, 0.4) turnfl=turnf turnf=0 } if(turnf==2) { ir1.Go(0) ir1.RotateDegrees(-90, 0.4) hwfd=hwf.Get() if(hwfd>0.4) { ir1.GoTo(0.2, 0.4) } else { ir1.GoTo((hwfd-0.14), 0.2) } ir1.RotateDegrees(-90, 0.4) turnfl=turnf turnf=0 } if(turnf==3) { ir1.Go(0) ir1.RotateDegrees(-90, 0.4) turnfl=turnf turnf=0 }		 if(turnf==34) { ir1.Go(0) ir1.RotateDegrees(-90, 0.4) ir1.GoTo(0.2, 0.4) ir1.RotateDegrees(-90, 0.4) turnfl=2 turnf=0 }	 if(turnf==4) { ir1.Go(0) ir1.RotateDegrees(90, 0.4) turnfl=turnf turnf=0 }		 if(turnf==44) { ir1.Go(0) ir1.RotateDegrees(90, 0.4) ir1.GoTo(0.2, 0.4) ir1.RotateDegrees(90, 0.4) turnfl=1 turnf=0 }
		else
		{ ir1.Go(0)
		wait 50
End
StartSimulationEngine  /FileName:"ch001.xml"
// zhangrelay
AddiRobotCreate ir1  	/Position:7  0.04  12
	/Orientation:0 0 0
	/ParentEntity:ir1
AddBoxShape
	/ParentEntity:ir1
	/Orientation:0 90 0
	/ParentEntity:ir1
AddBoxShape
	/ParentEntity:ir1
AddBoxShape
FlushScript
double iswall=0
double hwfd=0
double hwld=0
double hwrd=0
double turnf=0
double turnfl=0
wait 40000
Procedure  proc_main
	call proc_robot_0
End
Procedure  wall1
End
		hwfd=hwf.Get()
		hwrd=hwr.Get()
		hwld=hwl.Get()
		if(hwfd>0.4)
		{ iswall=0
		if(hwfd<0.2)
		if(iswall<1)
		{ ir1.Go(0.4)
		else
		{ ir1.Go(0)
		wait 50
End
原文链接:zhangrelay.blog.csdn.net/article/details/51353658
