ROS_Kinetic_10 ROS程序基础Eclipse_C++(一)
zhangrelay 发表于 2021/07/15 07:22:11 2021/07/15
【摘要】 ROS_Kinetic_10 ROS程序基础Eclipse_C++(一) 编写简单的消息发布器和订阅器 (C++) http://wiki.ros.org/cn/ROS/Tutorials/WritingPublisherSubscriber%28c%2B%2B%29 这里简单用Eclipse实现一下。 首相将talker.cpp和listener.cpp复制到hello_k...
这里简单用Eclipse实现一下。
首相将talker.cpp和listener.cpp复制到hello_kinetic/src目录下;
然后修改CMakeLists.txt;加入下列代码:
## Build talker and listener
include_directories(include ${catkin_INCLUDE_DIRS})
add_executable(kinetic_talker src/talker.cpp)
target_link_libraries(kinetic_talker ${catkin_LIBRARIES})
add_dependencies(kinetic_talker ${catkin_EXPORTED_TARGETS})
add_executable(kinetic_listener src/listener.cpp)
target_link_libraries(kinetic_listener ${catkin_LIBRARIES})
add_dependencies(kinetic_listener ${catkin_EXPORTED_TARGETS})
注意,可执行的节点不能重名,这里为kinetic_talker和kinetic_listener。
然后,就可以编译了,编译完成后。
开启终端,启动roscore:
-End-
原文链接:zhangrelay.blog.csdn.net/article/details/51494579
