ROS(indigo)国外开源示例包括多机器人控制等基于V-Rep和Gazebo的仿真
zhangrelay 发表于 2021/07/15 05:44:28 2021/07/15
【摘要】 ROS(indigo)国外开源示例包括多机器人的V-Rep和Gazebo仿真等 1 micros_swarm_framework 使用超级经典的stage。 http://wiki.ros.org/micros_swarm_framework代码的详细解释参考上面网址。 启动stage: roslaunch micros_swarm_framework swarm_in...
使用超级经典的stage。
启动stage:
  1. roslaunch micros_swarm_framework swarm_in_stage.launch
  2. <pre name="code" class="html">roslaunch micros_swarm_framework kernel.launch
roslaunch micros_swarm_framework app1.launch
roslaunch micros_swarm_framework app2.launch
2 Swarmathon(NASA)
  1. [NASA Swarmathon](http://www.nasaswarmathon.com)
  2. [iAnt robot swarms](http://swarms.cs.unm.edu)
  3. [University of New Mexico](http://www.unm.edu/)
  1. sudo apt-get install ros-indigo-robot-localization
  2. sudo apt-get install ros-indigo-hector-gazebo-plugins
  3. sudo apt-get install ros-indigo-joystick-drivers
https://github.com/BCLab-UNM/Swarmathon-ROS
~/rover_ws/Swarmathon_ROS$ ./run.sh
3 VRep-Ros Quadcopter Swarm
https://github.com/merosss/VRepRosQuadSwarm
  1. ~$ roscore
  2. ~/V-REP_PRO_EDU_V3_3_1_64_Linux$ ./vrep.sh
4 vrep_ros_bridge
这个例子可以测试机械臂,四旋翼飞行器和先锋机器人,这里以先锋机器人跟随二维码为例。
  1. ~$ roscore
  3. ~$ roslaunch demo_pioneer demo-visual-servo-pioneer-simulation.launch
5 vrep_youbot_plugin
带有机械手臂的移动机器人。安装使用说明请参考:
https://github.com/mfueller/vrep_youbot_plugin
-End-
原文链接:zhangrelay.blog.csdn.net/article/details/51737074
