ROS_Kinetic_23 ROS流行版本和相关书籍汇总
zhangrelay 发表于 2021/07/15 07:06:06 2021/07/15
【摘要】 目前,ROS使用的主流版本主要是下面四种:Hydro,Indigo,Jade,Kinetic。 Distro Release date Poster Tuturtle, turtle in tutorial EOL date ROS Kinetic Kame (Recommended) May 23rd, 2016 May, 2021 ROS ...
Distro
Release date
Poster
EOL date
ROS Kinetic Kame
(Recommended)
May 23rd, 2016
Kinetic Kame
Kinetic Kame
May, 2021
ROS Jade Turtle
May 23rd, 2015
Jade Turtle
Jade Turtle
May, 2017
ROS Indigo Igloo
July 22nd, 2014
I-turtle
I-turtle
April, 2019
(Trusty EOL)
ROS Hydro Medusa
September 4th, 2013
H-turtle
H-turtle
May, 2015
官方推荐版本为Kinetic。但是这四个版本的区别不算大,例如Hydro的源码无需
改动或很少改动就用于Kinetic,因此参考书只要是Hydro版本之后,都可以。
参考网址:1.ROS电子书及相关资料全集
                  2.http://books.exbot.net/
除了官网等资源,ROS相关参考书使我收获非常大,主要如下:
中文:
1 开源机器人操作系统-ROS
2 ROS机器人程序设计
3 ROS开源机器人控制基础
4 ROS入门实例
5 ExBotBooks
英文:
1 Learning Robotics Using Python
2 Learning ROS for Robotics Programming Second Edition
3 Mastering ROS for Robotics Programming
4 Programming Robots with ROS - A Practical introduction to the Robot Operating System
5 Robot Operating System (ROS) - The Complete Reference (Volume 1)
6 ROS By Example Volume 1 - A Do-It-Yourself Guide to the Robot Operating System
7 ROS By Example Volume 2 - Packages and Programs for Advanced Robot Behaviors
8 Learning ROS for Robotics Programming - Third Edition
9 ROS Robotics By Example
10 A Gentle Introduction to ROS
ROS和那些turtle
书中有诗和远方。
原文链接:zhangrelay.blog.csdn.net/article/details/52244746
