星火计划ROS机器人Spark
zhangrelay 发表于 2021/07/15 05:43:23 2021/07/15
【摘要】 星火计划ROS机器人Spark 1 http://wiki.ros.org/Robots/Spark 2 https://github.com/NXROBO/spark ---- Spark Spark is an affordable development platform for ROS applications, with mobil...
星火计划ROS机器人Spark
Spark
Spark is an affordable development platform for ROS applications, with mobility
and vision system.
Features:
Simple and practical:
Can be connected directly to laptop display, camera, speaker, microphone, etc.
High charge ability:
It can charge the robot and laptop at the same time, achieve long-term operation without intervention.
High extensibility:
Power output and installation site are provided. Accessories can be added on easily, such as:
- Camera head
- Loading platform
- Robot arm
- Lidar
Specs(standard)
Hardware: Mobile chassis, holder, Depth camera
Spec: Dimension: 700mm X 340mm X 340mm
  • Weight: 3.5kg
  • Max Payload: 6kg
  • Max Speed: 0.6m/s
  • Obstacle Clearance: 10mm
  • Battery Capacity: 45000mAh
Package Summary
Software for Spark base.
Documentation
  • Components of this meta-package:
  • spark_description : URDF model description of spark
  • spark_teleop : Keyboard teleoperation for spark
  • spark_bringup : A ROS node wrapper for the spark driver
  • spark_test : some testing program for spark
  • spark_base : the base driver for spark
  • ros_astra_camera : the camera driver for spark, checkout the here for more detail
  • ros_astra_launch : the launch package for spark camera driver, checkout the here for more detail
  • spark_follower: the follower person package for spark, it is an application for spark
Usage
Other
  • Use github to report bugs or request features.
  • Check www.nxrobo.com for more information!
Contact us
Email: info@nxrobo.com Website: http://www.nxrobo.com/
Spark
This repository contains the ROS wrapper of Sparks's driver plus various ROS applications.This is a meta-package.
Table of Contents
  1. Packages Overview
  2. Usage
  3. Mirror
Packages Overview
  • spark_v03 : spark 0.3 driver including base driver, camera driver, robot description, teleop package, and follow person package and so on.
  • tools : it contains the 3rd part openni2 driver which camera driver uses.
  • doc : it shows that how to compile and use this meta-package.
Usage
Prequirement
  • System: Ubuntu 14.04
  • ROS Version: Indigo(Desktop-Full Install)
Compile
Build this compile with the following steps:
#make a workspace
mkdir -p sparkws/src
cd sparkws/src
git clone https://github.com/NXROBO/spark.git
git checkout spark-03  //if your spark is the 0.3 base, please type the command:git checkout spark-04
cd ..
#installl dependence package
./src/spark/doc/install.sh
#Compile
catkin_make
#Install
catkin_make install
If everything goes fine, test the follow-person example as follow:
./install/follow_run.sh
Mirror
We also provide a downloadable mirror whose all environments have been configured.
火花
Spark是用于ROS应用程序的可负担的开发平台,具有移动性
和视觉系统。
特征:
简单实用:
可以直接连接到笔记本电脑显示器,相机,扬声器,麦克风等。
高充电能力:
同时可以对机器人和笔记本电脑进行充电,无需干预即可实现长期运行。
高延展性
提供电源输出和安装地点。配件可以轻松添加,如:
- 相机头
- 装载平台
- 机器人手臂
- 激光雷达
规格(标准)
硬件:移动底盘,支架,深度相机
规格:尺寸:700mm X 340mm X 340mm
  • 重量:3.5kg
  • 最大有效载荷:6kg
  • 最大速度:0.6m / s
  • 障碍物间隙:10mm
  • 电池容量:45000mAh
软件包摘要
Spark基础软件。
文档
  • 此元包的组件:
  • spark_description:URDF模型描述火花
  • spark_teleop:用于火花的键盘远程操作
  • spark_bringup:Spark驱动程序的ROS节点包装器
  • spark_test:一些火花测试程序
  • spark_base:火花的基本驱动程序
  • ros_astra_camera:相机驱动程序为火花,结帐在这里更多的细节
  • ros_astra_launch:火花相机驱动程序的发射包,在这里查看更多的细节
  • spark_follower:跟随者包装为火花,它是火花的应用程序
用法
其他
  • 使用github报告错误或请求功能。
  • 请访问www.nxrobo.com了解更多信息!
联系我们
电邮:info@nxrobo.com网站:http : //www.nxrobo.com/
火花
该存储库包含Sparks驱动程序的ROS包装器以及各种ROS应用程序。这是一个元包。
目录
  1. 套餐概述
  2. 用法
  3. 镜子
套餐概述
  • spark_v03:火花0.3驱动程序,包括基本驱动程序,摄像头驱动程序,机器人描述,电视包装和跟随人员包装等。
  • 工具:它包含相机驱动程序使用的第3部分openni2驱动程序。
  • doc:它显示了如何编译和使用这个元包。
用法
Prequirement
  • 系统:Ubuntu 14.04
  • ROS版本:靛蓝(桌面完全安装)
编
使用以下步骤构建此编译:
#使工作区
的mkdir -p sparkws / src目录
CD sparkws / src目录
混帐克隆https://github.com/NXROBO/spark.git
git的结帐火花-03 //如果你的火花是在0.3的基础上,请键入命令:混帐结账火花-04
CD ..
# installl依赖包
#编译
catkin_make
#安装
catkin_make安装
如果一切顺利,请测试以下人员的例子如下:
镜子
我们还提供一个可下载的镜像,其所有环境都已配置。
原文链接:zhangrelay.blog.csdn.net/article/details/72821566
