ROS机器人项目开发11例-ROS Robotics Projects(4)物体检测与识别
zhangrelay 发表于 2021/07/15 04:55:09 2021/07/15
【摘要】 ROS Robotics Projects(4)物体检测与识别 这是本书的第6章,包括使用单目和深度视觉,分别为2D和3D的检测和识别。 用到了一些Github上已有的库和功能包。 以find_object_2d为例(http://wiki.ros.org/find_object_2d): 补充参考:https://github.com/introlab/find...
补充参考:https://github.com/introlab/find-object
3D物体识别(https://github.com/wg-perception)
ROS包:
      ~$ sudo apt-get install ros-indigo-object-
      ros-indigo-object-msgs
      ros-indigo-object-msgs-tools
      ros-indigo-object-recognition-capture
      ros-indigo-object-recognition-core
      ros-indigo-object-recognition-linemod
      ros-indigo-object-recognition-msgs
      ros-indigo-object-recognition-reconstruction
      ros-indigo-object-recognition-renderer
      ros-indigo-object-recognition-ros
      ros-indigo-object-recognition-ros-visualization
      ros-indigo-object-recognition-tabletop
      ros-indigo-object-recognition-tod
      ros-indigo-object-recognition-transparent-objects
两个重要的功能包: find_object_2d+object_recognition。
原文链接:zhangrelay.blog.csdn.net/article/details/77248232
评论(0
