在Ubuntu 18.04 LTS使用colcon工具编译ROS 1/2包
zhangrelay 发表于 2021/07/15 04:03:47 2021/07/15
【摘要】 ROSwiki官网推荐了新的软件包编译工具colcon。ROS编译工具主要经历了三个阶段: 1. catkin 2. ament 3. colcon。 什么是colcon? colcon is a command line tool to improve the workflow of building, testing and using multiple software...
什么是colcon?
colcon is a command line tool to improve the workflow of building, testing and using multiple software packages.It automates the process, handles the ordering and sets up the environment to use the packages.
colcon是一个命令行工具,用于改进编译,测试和使用多个软件包的工作流程。它实现过程自动化,处理需求并设置环境以便于使用软件包。
安装和使用,请参考:http://colcon.readthedocs.io/en/latest/index.html
下面简述流程:
一共两步:
1. sudo apt install python3-colcon-common-extensions
2. colcon build (source install/setup.bash )
具体使用教程参考官网链接进行。
编译过程如下:
  1. Starting >>> roscpp_tutorials
  2. Starting >>> rospy_tutorials
  3. Starting >>> turtlesim
  4. --- stderr: rospy_tutorials
  5. CMake Warning:
  6. Manually-specified variables were not used by the project:
  7. CATKIN_INSTALL_INTO_PREFIX_ROOT
  8. ---
  9. Finished <<< rospy_tutorials [16.41s]
  10. --- stderr: turtlesim
  11. CMake Warning:
  12. Manually-specified variables were not used by the project:
  13. CATKIN_INSTALL_INTO_PREFIX_ROOT
  14. ---
  15. Finished <<< turtlesim [29.56s]
  16. --- stderr: roscpp_tutorials
  17. CMake Warning:
  18. Manually-specified variables were not used by the project:
  19. CATKIN_INSTALL_INTO_PREFIX_ROOT
  20. ---
  21. Finished <<< roscpp_tutorials [39.06s]
  22. Starting >>> ros_tutorials
  23. --- stderr: ros_tutorials
  24. CMake Warning:
  25. Manually-specified variables were not used by the project:
  26. CATKIN_INSTALL_INTO_PREFIX_ROOT
  27. ---
  28. Finished <<< ros_tutorials [2.63s]
  29. Summary: 4 packages finished [42.15s]
  30. 4 packages had stderr output: ros_tutorials roscpp_tutorials rospy_tutorials turtlesim
原文链接:zhangrelay.blog.csdn.net/article/details/80922056
