机器人操作系统(ROS)集成开发环境(IDE)VS Code插件更新
zhangrelay 发表于 2021/07/15 03:39:40 2021/07/15
【摘要】 机器翻译: ROS引入VS Code插件现在更新了!更新为Windows系统添加插件,增加了内置工作空间的覆盖范围catkin_make_isolated,并更新了ROS Core监视器。未来的迭代中将出现更多功能,如本地调试和URDF渲染等。 非常感谢@ajshort的原作者,以及所有的支持! 注意:此扩展的更新将作为新扩展发布。请卸载以前的版本以确保没有冲突。 有...
机器翻译:
有关功能请求和错误报告,请在ms-iot/vscode-ros页面发布。期待这个项目像ROS本身一样发展=)
有关此项目和Windows上的ROS的更多详细信息,请查看链接http://aka.ms/ros。
原文如下:
@james wrote:
We are excited to introduce an update for the VS Code extension for ROS! This update brings the extension to Windows, adds coverage for workspaces built with catkin_make_isolated, and updates the ROS Core monitor. More capabilities like local debugging and URDF rendering are coming in future iterations.
Huge thanks to @ajshort, the original author, for all the support along the way!
Note: This update to the extension is published as a new extension. Please uninstall the previous release to ensure no conflicts.
For feature requests and bug reports, please post in the ms-iot/vscode-ros repository. Let’s keep this project evolving just like ROS itself =)
For more details about this project and ROS on Windows, please check out http://aka.ms/ros.
原文链接:zhangrelay.blog.csdn.net/article/details/94432994
