HDLBits 系列(14) Latch and Dff and Edge detect
李锐博恩 发表于 2021/07/15 01:51:14 2021/07/15
【摘要】 目录 D Latch DFF + GATE Mux + DFF MUX2 + DFF FSM JK 触发器 Edgedetect(边沿检测) 双边沿检测   D Latch Implement the following circuit: 这是一个锁存器,高电平跟随,低电平保持,于是设计: module top_module ( in...
目录
D Latch
DFF + GATE
Mux + DFF
MUX2 + DFF
FSM
JK 触发器
Edgedetect(边沿检测)
双边沿检测
D Latch
  1. module top_module (
  2. input d,
  3. input ena,
  4. output q);
  5. always@(*)begin
  6. if(ena) q = d;
  7. else ;
  8. end
  9. endmodule
DFF + GATE
  2. input clk,
  3. input in,
  4. output out);
  5. always@(posedge clk) begin
  6. out <= in ^ out;
  7. end
  8. endmodule
Mux + DFF
Taken from ECE253 2015 midterm question 5
Consider the sequential circuit below:
Assume that you want to implement hierarchical Verilog code for this circuit, using three instantiations of a submodule that has a flip-flop and multiplexer in it. Write a Verilog module (containing one flip-flop and multiplexer) named top_module for this submodule.
假设您要使用其中具有触发器和多路复用器的子模块的三个实例化来为此电路实现分层的Verilog代码。 为此子模块编写一个名为top_module的Verilog模块(包含一个触发器和多路复用器)。
要求写出其中一个子模块即可:
  2. input clk,
  3. input L,
  4. input r_in,
  5. input q_in,
  6. output reg Q);
  7. wire mid;
  8. assign mid = L ? r_in : q_in;
  9. always@(posedge clk) begin
  10. Q <= mid;
  11. end
  12. endmodule
其实读者应该自己用例化的方式,把整个电路实现了。
MUX2 + DFF
Consider the n-bit shift register circuit shown below:
Write a Verilog module named top_module for one stage of this circuit, including both the flip-flop and multiplexers.
  2. input clk,
  3. input w, R, E, L,
  4. output Q
  5. );
  6. reg Q;
  7. wire mid1, mid2;
  8. assign mid1 = E ? w : Q;
  9. assign mid2 = L ? R : mid1;
  10. always@(posedge clk) begin
  11. Q <= mid2;
  12. end
  13. endmodule
FSM
Given the finite state machine circuit as shown, assume that the D flip-flops are initially reset to zero before the machine begins.
Build this circuit.
  2. input clk,
  3. input x,
  4. output z
  5. );
  6. reg q1, q2, q3;
  7. always@(posedge clk) begin
  8. q1 <= q1 ^ x;
  9. q2 <= ~q2 & x;
  10. q3 <= ~q3 | x;
  11. end
  12. assign z = ~(q1 | q2 | q3);
  13. endmodule
JK 触发器
A JK flip-flop has the below truth table. Implement a JK flip-flop with only a D-type flip-flop and gates. Note: Qold is the output of the D flip-flop before the positive clock edge.
J K Q
0 0 Qold
0 1 0
1 0 1
1 1 ~Qold
  2. input clk,
  3. input j,
  4. input k,
  5. output Q);
  6. always@(posedge clk) begin
  7. if(~j & ~k) Q <= Q;
  8. else if(j&k) Q <= ~Q;
  9. else if(~j & k) Q <= 0;
  10. else Q <= 1;
  11. end
  12. endmodule
Edgedetect(边沿检测)
For each bit in an 8-bit vector, detect when the input signal changes from 0 in one clock cycle to 1 the next (similar to positive edge detection). The output bit should be set the cycle after a 0 to 1 transition occurs.
Here are some examples. For clarity, in[1] and pedge[1] are shown separately.
对于8位向量中的每个位,检测输入信号何时从一个时钟周期的0变为下一时钟周期的1(类似于上升沿检测)。 输出位应在发生0到1转换后的周期内进行设置。
这里有些例子。 为了清楚起见,分别显示了in [1]和pedge [1]。
  2. input clk,
  3. input [7:0] in,
  4. output [7:0] pedge
  5. );
  6. reg [7:0] in_r1, in_r2;
  8. in_r1 <= in;
  9. in_r2 <= in_r1;
  10. end
  11. assign pedge = ~in_r2 & in_r1;
  12. endmodule
双边沿检测
For each bit in an 8-bit vector, detect when the input signal changes from one clock cycle to the next (detect any edge). The output bit should be set the cycle after a 0 to 1 transition occurs.
Here are some examples. For clarity, in[1] and anyedge[1] are shown separately
  2. input clk,
  3. input [7:0] in,
  4. output [7:0] anyedge
  5. );
  8. in_r1 <= in;
  9. in_r2 <= in_r1;
  10. end
  11. assign anyedge = in_r2 ^ in_r1;
  12. endmodule
文章来源: reborn.blog.csdn.net,作者:李锐博恩,版权归原作者所有,如需转载,请联系作者。
原文链接:reborn.blog.csdn.net/article/details/103226673
