DeepChem | 基于图卷积预测分子的溶解度
DrugAI 发表于 2021/07/15 01:28:52 2021/07/15
【摘要】 如何使用DeepChem库将图卷积用于类似问题的回归分析。 from deepchem.models.tensorgraph.layers import GraphPool, GraphGatherfrom deepchem.models.tensorgraph.layers import Dense, L2Loss, WeightedError, Stackfrom ...
  1. from deepchem.models.tensorgraph.layers import GraphPool, GraphGather
  2. from deepchem.models.tensorgraph.layers import Dense, L2Loss, WeightedError, Stack
  3. from deepchem.models.tensorgraph.layers import Label, Weights
  4. import numpy as np
  5. import tensorflow as tf
  6. import os
  1. num_epochs = 50
  2. batch_size = 200
  3. pad_batches = True
  4. tg = TensorGraph(batch_size=batch_size,learning_rate=0.0005,use_queue=False)
  5. prediction_tasks = ['cLogP','cLogS']
  6. def read_data(input_file_path):
  7. featurizer = dc.feat.ConvMolFeaturizer()
  8. loader = dc.data.CSVLoader(tasks=prediction_tasks, smiles_field="Smiles", featurizer=featurizer)
  9. dataset = loader.featurize(input_file_path, shard_size=8192)
  10. # Initialize transformers
  11. transformer = dc.trans.NormalizationTransformer(transform_w&
文章来源: drugai.blog.csdn.net,作者:DrugAI,版权归原作者所有,如需转载,请联系作者。
原文链接:drugai.blog.csdn.net/article/details/106069191
评论(0
