Win10系统的ROS机器人操作系统1和2新一轮更新-2021-01-
zhangrelay 发表于 2021/07/15 00:51:51 2021/07/15
【摘要】 win10的iot又迎来了新一轮更新,嗯,这次只有noetic和foxy了!!! 其他版本的ros可以停止学习和研究了,算法各平台通用,也无需在乎版本问题。 选择noetic和foxy最稳! Foxy Microsoft Azure Edge Robotics团队很高兴宣布面向Windows开发人员的Foxy版本v20201211.0.0.2012290002。 ...
选择noetic和foxy最稳!
Foxy
  1. mkdir c:\opt\chocolatey
  2. set ChocolateyInstall=c:\opt\chocolatey
  3. choco source add -n=ros-win -s="https://aka.ms/ros/public" --priority=1
  4. choco upgrade ros-foxy-desktop -y --execution-timeout=0
Some highlights of this release:
Love your feedback and let us know on GitHub.
Also check out https://aka.ms/ros for ROS related components from Microsoft and partners which are supported on Linux and Windows. And more getting started tutorials on https://aka.ms/ros/docs.
Noetic
The Microsoft Azure Edge Robotics team is happy to announce another Noetic Release v20201214.0.0.2012281717 for Windows developers.
As usual, you can install it by the following steps:
  4. choco upgrade ros-noetic-desktop_full -y --execution-timeout=0
  • Based on the Noetic release sync 2020-12-14
  • Enabled packages:
    • Desktop_full
    • MoveIt
    • Navigation
    • ROSBridge_suite
    • SLAM
      • Cartographer
      • OpenKarto
  • Libraries and Python:
    • Boost 1.73.0
    • CMake 3.18.2
    • EmPY 3.3.4
    • Gazebo 10.2.0
    • OGRE 1.12.7
    • OpenCV 4.3.0
    • OpenSSL 1.1.1g
    • PCL 1.9.1
    • Poco 1.9.2
    • Python 3.8.3 (embeddable distribution)
    • Qt 5.15.0
原文链接:zhangrelay.blog.csdn.net/article/details/112204603
