Windows安装和使用ROS1Noetic和ROS2Foxy记录
zhangrelay 发表于 2021/07/15 01:48:56 2021/07/15
【摘要】 更新了一下win下的ROS,开发课程需要,必须使用最新版本的ROS。 安装: Noetic Foxy 使用一切正常: 附(安装记录): C:\ros_ws>choco upgrade ros-foxy-desktop -y --execution-timeout=0 Chocolatey v0.10.11 Upgrading the foll...
安装:
Noetic
Foxy
使用一切正常:
附(安装记录):
C:\ros_ws>choco upgrade ros-foxy-desktop -y --execution-timeout=0 Chocolatey v0.10.11 Upgrading the following packages: ros-foxy-desktop By upgrading you accept licenses for the packages. ros-foxy-desktop is not installed. Installing... Progress: Downloading ros-foxy-desktop 20201211.0.0.2012290002... 100% Progress: Downloading ros-foxy-desktop 20201211.0.0.2012290002... 100% ros-foxy-desktop v20201211.0.0.2012290002 ros-foxy-desktop package files upgrade completed. Performing other installation steps. Installing ros-foxy-desktop... ros-foxy-desktop has been installed. ros-foxy-desktop can be automatically uninstalled. The upgrade of ros-foxy-desktop was successful. Software installed to 'c:\opt\ros\foxy\x64\' Chocolatey upgraded 1/1 packages. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log). C:\ros_ws>choco upgrade ros-noetic-desktop_full -y --execution-timeout=0 Chocolatey v0.10.11 Upgrading the following packages: ros-noetic-desktop_full By upgrading you accept licenses for the packages. ros-noetic-desktop_full is not installed. Installing... Progress: Downloading ros-noetic-desktop_full 20201214.0.0.2012281717... 100% Progress: Downloading ros-noetic-desktop_full 20201214.0.0.2012281717... 100% ros-noetic-desktop_full v20201214.0.0.2012281717 ros-noetic-desktop_full package files upgrade completed. Performing other installation steps. Installing ros-noetic-desktop_full... ros-noetic-desktop_full has been installed. ros-noetic-desktop_full can be automatically uninstalled. The upgrade of ros-noetic-desktop_full was successful. Software installed to 'c:\opt\ros\noetic\x64\' Chocolatey upgraded 1/1 packages. See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log). C:\ros_ws>
原文链接:zhangrelay.blog.csdn.net/article/details/112250701
