物体检测YOLOv3实践(2)
可爱又积极 发表于 2021/07/09 11:03:39 2021/07/09
【摘要】 开始训练In [8]:from keras.optimizers import Adamfrom yolo3.utils import get_random_data # 设置所有的层可训练for i in range(len(model.layers)): model.layers[i].trainable = True # 选择Adam优化器,设置学习率learning_ra...
开始训练
In [8]:
# 设置所有的层可训练
# 选择Adam优化器,设置学习率
learning_rate = 1e-4
model.compile(optimizer=Adam(lr=learning_rate), loss={'yolo_loss': lambda y_true, y_pred: y_pred})
# 设置批大小和训练轮数
batch_size = 16
max_epochs = 2
print('Train on {} samples, val on {} samples, with batch size {}.'.format(num_train, num_val, batch_size))
# 开始训练
model.fit_generator(data_generator_wrapper(lines[:num_train], batch_size, input_shape, data_path,anchors, num_classes),
    steps_per_epoch=max(1, num_train//batch_size),
    validation_data=data_generator_wrapper(lines[num_train:], batch_size, input_shape, data_path,anchors, num_classes),
    validation_steps=max(1, num_val//batch_size),
    epochs=max_epochs,
    initial_epoch=0,
    callbacks=[reduce_lr, early_stopping])
Train on 179 samples, val on 19 samples, with batch size 16.
Epoch 1/2
11/11 [==============================] - 29s 3s/step - loss: 46.9689 - val_loss: 45.4452
Epoch 2/2
11/11 [==============================] - 5s 437ms/step - loss: 45.4349 - val_loss: 45.0633
Out[8]:
<keras.callbacks.History at 0x7fdd6ba012e8>
保存模型
In [9]:
import os
os.makedirs(save_path)
# 保存模型
model.save_weights(os.path.join(save_path, 'trained_weights_final.h5'))
模型测试
打开一张测试图片
In [10]:
from PIL import Image
import numpy as np
# 测试文件路径
test_file_path = './test.jpg'
# 打开测试文件
image = Image.open(test_file_path)
image_ori = np.array(image)
image_ori.shape
Out[10]:
(640, 481, 3)
图片预处理
In [11]:
from yolo3.utils import letterbox_image
new_image_size = (image.width - (image.width % 32), image.height - (image.height % 32))
boxed_image = letterbox_image(image, new_image_size)
image_data = np.array(boxed_image, dtype='float32')
image_data /= 255.
image_data = np.expand_dims(image_data, 0)
image_data.shape
Out[11]:
(1, 640, 480, 3)
In [12]:
import keras.backend as K
sess = K.get_session()
构建模型
In [13]:
from yolo3.model import yolo_body
from keras.layers import Input
# coco数据anchor值文件存储位置
anchor_path = "./model_data/yolo_anchors.txt"
with open(anchor_path) as f:
    anchors = f.readline()
anchors = [float(x) for x in anchors.split(',')]
anchors = np.array(anchors).reshape(-1, 2)
yolo_model = yolo_body(Input(shape=(None,None,3)), len(anchors)//3, num_classes)
加载模型权重,或将模型路径替换成上一步训练得出的模型路径
In [14]:
# 模型权重存储路径
weights_path = "./model_data/yolo.h5"
yolo_model.load_weights(weights_path)
定义IOU以及score:
  • IOU: 将交并比大于IOU的边界框作为冗余框去除
  • score:将预测分数大于score的边界框筛选出来
In [15]:
iou = 0.45
score = 0.8
构建输出[boxes, scores, classes]
In [16]:
from yolo3.model import yolo_eval
input_image_shape = K.placeholder(shape=(2, ))
boxes, scores, classes = yolo_eval(
    yolo_model.output,
    anchors,
    num_classes,
    input_image_shape,
    score_threshold=score,
    iou_threshold=iou)
进行预测
In [17]:
out_boxes, out_scores, out_classes = sess.run(
    [boxes, scores, classes],
    feed_dict={
        yolo_model.input: image_data,
        input_image_shape: [image.size[1], image.size[0]],
        K.learning_phase(): 0
In [18]:
class_coco = get_classes(classes_path)
out_coco = []
for i in out_classes:
    out_coco.append(class_coco[i])
In [19]:
print(out_boxes)
print(out_scores)
print(out_coco)
[[152.6994   166.27255  649.0503   459.93747 ]
 [ 68.62152   21.843102 465.6621   452.6878  ]]
[0.9838943 0.999688 ]
['person', 'umbrella']
将预测结果绘制在图片上
In [20]:
from PIL import Image, ImageFont, ImageDraw
font = ImageFont.truetype(font='font/FiraMono-Medium.otf',
                    size=np.floor(3e-2 * image.size[1] + 0.5).astype('int32'))
thickness = (image.size[0] + image.size[1]) // 300
for i, c in reversed(list(enumerate(out_coco))):
    predicted_class = c
    box = out_boxes[i]
    score = out_scores[i]
    label = '{} {:.2f}'.format(predicted_class, score)
    draw = ImageDraw.Draw(image)
    label_size = draw.textsize(label, font)
    top, left, bottom, right = box
    top = max(0, np.floor(top + 0.5).astype('int32'))
    left = max(0, np.floor(left + 0.5).astype('int32'))
    bottom = min(image.size[1], np.floor(bottom + 0.5).astype('int32'))
    right = min(image.size[0], np.floor(right + 0.5).astype('int32'))
    print(label, (left, top), (right, bottom))
    if top - label_size[1] >= 0:
        text_origin = np.array([left, top - label_size[1]])
    else:
        text_origin = np.array([left, top + 1])
    for i in range(thickness):
        draw.rectangle(
            [left + i, top + i, right - i, bottom - i],
            outline=225)
    draw.rectangle(
        [tuple(text_origin), tuple(text_origin + label_size)],
        fill=225)
    draw.text(text_origin, label, fill=(0, 0, 0), font=font)
    del draw
umbrella 1.00 (22, 69) (453, 466)
person 0.98 (166, 153) (460, 640)
In [21]:
Out[21]:
