GaussDB(DWS) 列存表一些常用信息查询使用
ACBD 发表于 2021/07/05 17:15:59 2021/07/05
【摘要】 列存表一些常用信息查询使用 列存表一些常用信息查询SQL示例 建列存分区表CREATE TABLE column_table(    state_ID INT,    state_NAME VARCHAR2(40),    area_ID INT,    ready BOOLEAN)WITH (ORIENTATION = COLUMN)PARTITION BY range(area_ID)(...
列存表一些常用信息查询使用
  • 列存表一些常用信息查询SQL示例
  • 建列存分区表
    state_ID INT,
    area_ID INT,
    ready BOOLEAN
partition column_table_p1 values less than(60),
partition column_table_p2 values less than(80),
partition column_table_p3 values less than(95),
partition column_table_p4 values less than(100));
insert into column_table values(1, 'Hong', 72);
insert into column_table values(2, 'Eason', 89);
insert into column_table values(3, 'Jolin', 21);
insert into column_table values(4, 'Lily', 49);
insert into column_table values(5, 'Sinco', 99);
insert into column_table values(6, 'Rain', 89);
  • 查询分区边界
select relname, partstrategy, boundaries from pg_partition where parentid=(select parentid from pg_partition where relname='column_table');
     relname     | partstrategy | boundaries
 column_table_p1 | r            | {60}
 column_table_p2 | r            | {80}
 column_table_p3 | r            | {95}
 column_table_p4 | r            | {100}
 column_table    | r            |
(5 rows)
  • 查询列存表列数
select count(*) from ALL_TAB_COLUMNS where table_name='column_table';
 count
     4
(1 row)
  • 查询数据在各DN分布
select table_skewness('column_table');
           table_skewness
 ("dn_6009_6010        ",3,50.000%)
 ("dn_6003_6004        ",1,16.667%)
 ("dn_6005_6006        ",1,16.667%)
 ("dn_6007_6008        ",1,16.667%)
 ("dn_6001_6002        ",0,0.000%)
 ("dn_6011_6012        ",0,0.000%)
(6 rows)
  • 查询某一有数据分布DN上分区P1所对应的cudesc和delta表名称
execute direct on (dn_6003_6004) 'select a.relname from pg_class a, pg_partition b where (a.oid=b.reldeltarelid or a.oid=b.relcudescrelid) and b.relname=''column_table_p1''';
       relname
 pg_cudesc_part_16455
 pg_delta_part_16455
(2 rows)
  • 查询某一有数据分布DN上分区P1所对应的cudesc数据
连接该DN
select * from cstore.pg_cudesc_part_16455;
 col_id | cu_id | min  | max  | row_count | cu_mode |    size    | cu_pointer | magic  | extra
      1 |  1001 | \x04 | \x04 |         1 |       3 |          0 |            | 210126 |
      2 |  1001 | Lily | Lily |         1 |       3 |          0 |            | 210126 |
      3 |  1001 | 1    | 1    |         1 |       3 |          0 |            | 210126 |
      4 |  1001 |      |      |         1 |       2 |          0 |            | 210126 |
    -10 |  1001 |      |      |         1 |         | 1625474927 |            | 210126 |
(5 rows)
  • 查询cudesc存储位置
select * from pg_relation_filepath('cstore.pg_cudesc_part_16455');
 base/16393/16459
(1 row)
