C# 属性(二)
MICAR 发表于 2021/07/02 14:44:33 2021/07/02
【摘要】 抽象属性(Abstract Properties)抽象类可拥有抽象属性,这些属性应在派生类中被实现。下面的程序说明了这点:实例using System;namespace runoob{   public abstract class Person   {      public abstract string Name      {         get;         set;   ...
实例
using System;
namespace runoob
         get;
         set;
      public abstract int Age
         get;
         set;
   class Student : Person
      private string code = "N.A";
      private string name = "N.A";
      private int age = 0;
      // 声明类型为 string 的 Code 属性
      public string Code
         get
            return code;
         set
            code = value;
      // 声明类型为 string 的 Name 属性
      public override string Name
         get
            return name;
         set
            name = value;
      // 声明类型为 int 的 Age 属性
      public override int Age
         get
            return age;
         set
            age = value;
      public override string ToString()
         return "Code = " + Code +", Name = " + Name + ", Age = " + Age;
   class ExampleDemo
      public static void Main()
         // 创建一个新的 Student 对象
         Student s = new Student();
         // 设置 student 的 code、name 和 age
         s.Code = "001";
         s.Name = "Zara";
         s.Age = 9;
         Console.WriteLine("Student Info:- {0}", s);
         // 增加年龄
         s.Age += 1;
         Console.ReadKey();
当上面的代码被编译和执行时,它会产生下列结果:
Student Info: Code = 001, Name = Zara, Age = 9
Student Info: Code = 001, Name = Zara, Age = 10
