oracle grid HAIP启动失败
snowofsummer 发表于 2021/07/01 16:18:08 2021/07/01
【摘要】 参考手册:AIX: HAIP fails to start with "OS error: 22" due to non-related devices using same major device number 报错信息:$GRID_HOME/log/<hostname>/agent/ohasd/orarootagent_root/orarootagent_root.log2012-03...
参考手册:
报错信息:
2012-03-29 09:27:34.258: [ USRTHRD][4371] {0:0:209} Arp::sCreateSocket {
2012-03-29 09:27:44.264: [ USRTHRD][4371] {0:0:209} failed to create arp
2012-03-29 09:27:44.264: [ USRTHRD][4371] {0:0:209} (null) category: -2, operation: SETIF, loc: bpfopen:21,o, OS error: 22, other: dev /dev/bpf0, ifr en15
2012-03-29 09:27:44.264: [ USRTHRD][4371] {0:0:209} [NetHAWork] thread hit exception failed to create ARP
2012-03-29 09:27:44.264: [ USRTHRD][4371] {0:0:209} [NetHAWork] thread stopping
2012-03-29 09:27:44.264: [ USRTHRD][4371] {0:0:209} Thread:[NetHAWork]isRunning is reset to false here
2012-03-29 09:27:46.175: [ USRTHRD][4114] {0:0:209} HAIP: Moving ip '' from inf 'en15' to inf 'en15'
2012-03-29 09:27:46.175: [ USRTHRD][4114] {0:0:209} pausing thread
2012-03-29 09:27:46.175: [ USRTHRD][4114] {0:0:209} posting thread
2012-03-29 09:27:46.175: [ USRTHRD][4114] {0:0:209} Waiting for HAIP work thread to cleanup ARP
2012-03-29 09:27:48.175: [ USRTHRD][4114] {0:0:209} timeout to wait thread to cleanup ARP
/tmp/bpf_*.log
Apr 02 17:38:06.112 | [ 70 ] ioctl: failed req 2149597804, args 114eed5f0, errno 22
Apr 02 17:38:06.212 | [ 71 ] ioctl: failed req 2149597804, args 114eed5f0, errno 22
Apr 02 17:38:06.312 | [ 72 ] ioctl: failed req 2149597804, args 114eed5f0, errno 22
Apr 02 17:38:06.412 | [ 73 ] ioctl: failed req 2149597804, args 114eed5f0, errno 22
Apr 02 17:38:06.512 | [ 74 ] ioctl: failed req 2149597804, args 114eed5f0, errno 22
错误原因:
bpf设备号和dlmadrv设备号冲突
解决办法:
修改冲突设备的major/minor 。
报错
