Python构建企业微信自动消息转发服务端【生长吧!Python】
kaliarch 发表于 2021/06/23 13:07:15 2021/06/23
【摘要】 目前有在项目分组,就小组成员中,微信群消息回复较多的情况下,想根据组来转发特定消息,包含文字、图片、语言等。在此只是自己实现仅供参考,可以根据自身需求修改更多功能。
一、背景
二、代码
2.1 企业微信相关信息
  • 企业ID:corpid
  • 自建应用appid
  • 自建应用secret
2.2 服务端部署
运行环境:
python 版本 2.7
git clone https://github.com/redhatxl/wechatmsg.git
nohup python2.7 wechatmsg/wx_msg_server.py &
2.3 参考RUL:
获取access_token
发送消息
2.4 代码
# flask 框架后台
  def server_run(self):
        app = Flask(__name__)
        @app.route('/index', methods=['GET', 'POST'])
        def index():
            wxcpt = WXBizMsgCrypt(self.sToken, self.sEncodingAESKey, self.sCorpID)
            # 获取url验证时微信发送的相关参数
            sVerifyMsgSig = request.args.get('msg_signature')
            sVerifyTimeStamp = request.args.get('timestamp')
            sVerifyNonce = request.args.get('nonce')
            sVerifyEchoStr = request.args.get('echostr')
            # 验证url
            if request.method == 'GET':
                ret, sEchoStr = wxcpt.VerifyURL(sVerifyMsgSig, sVerifyTimeStamp, sVerifyNonce, sVerifyEchoStr)
                print type(ret)
                print type(sEchoStr)
                if (ret != 0):
                    print "ERR: VerifyURL ret:" + str(ret)
                    sys.exit(1)
                return sEchoStr
            # 接收客户端消息
            if request.method == 'POST':
                sReqMsgSig = sVerifyMsgSig
                sReqTimeStamp = sVerifyTimeStamp
                sReqNonce = sVerifyNonce
                sReqData = request.data
                print(sReqData)
                ret, sMsg = wxcpt.DecryptMsg(sReqData, sReqMsgSig, sReqTimeStamp, sReqNonce)
                print ret, sMsg
                if (ret != 0):
                    print "ERR: DecryptMsg ret: " + str(ret)
                    sys.exit(1)
                # 解析发送的内容并打印
                xml_tree = ET.fromstring(sMsg)
                print('xml_tree is ', xml_tree)
  • 消息内容发送
 def _send_text_msg(self, content):
        data = {
            "touser": ('|').join(self.userid.split(',')),
            "toparty": ('|').join(self.partid.split(',')),
            # "toparty":int(self.partid),
            "msgtype": "text",
            "agentid": self.agent_id,
            "text": {
                "content": content
            "safe": 0
        try:
            response = requests.post(self.send_msg_url.format(self.access_token), json.dumps(data))
            self.logoper.info(response.text)
            print(response.text)
            result_msg = json.loads(response.content)['errmsg']
            return result_msg
        except Exception as e:
            self.logoper.info(e)
  • 日志
   def create_dir(self):
        创建目录
        :return: 文件名称
        _LOGDIR = os.path.join(os.path.dirname(__file__), self.logdir_name)
        _TIME = time.strftime('%Y-%m-%d', time.gmtime()) + '-'
        _LOGNAME = _TIME + self.logfile_name
        LOGFILENAME = os.path.join(_LOGDIR, _LOGNAME)
        if not os.path.exists(_LOGDIR):
            os.mkdir(_LOGDIR)
        return LOGFILENAME
    def create_logger(self, logfilename):
        创建logger对象
        :param logfilename:
        :return: logger对象
        logger = logging.getLogger()
        logger.setLevel(logging.INFO)
        handler = logging.FileHandler(logfilename)
        handler.setLevel(logging.INFO)
        formater = logging.Formatter('%(asctime)s - %(name)s - %(levelname)s - %(message)s')
        handler.setFormatter(formater)
        logger.addHandler(handler)
        return logger
配置文件
# 定义微信公众号信息
[common]
# 企业微信企业ID
corpid = wxe23xxxxxxxxxxx
# 接收消息服务器配置
[recmsg]
Token = mVNAAw3xxxxxxxxxxxxxxxxx
EncodingAESKey = vwbKImxc3WPeE073xxxxxxxxxxxxxxxxxx
# 自建应用信息
[appconfig]
# 自建应用agentid
agentid = 1000002
# 自建应用secret
secret = 6HAGX7Muw36pv5anxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# 消息接收信息
# 消息接收用户id,如果多个用户用英文','隔开
userid = xuel|yaoy
# 消息接收部门id,如果多个用英文','隔开
partid = 11
[urlconfig]
# 获取应用token的api接口
get_access_token_url = https://qyapi.weixin.qq.com/cgi-bin/gettoken?corpid={}&corpsecret={}
# 发送消息api接口
send_msg_url = https://qyapi.weixin.qq.com/cgi-bin/message/send?access_token={}
# 上传媒体api接口,获取mediaid
upload_media_url = https://qyapi.weixin.qq.com/cgi-bin/media/upload?access_token={}&type=image
# 上传高清语音接口
upload_video_url = https://qyapi.weixin.qq.com/cgi-bin/media/get/jssdk?access_token={}&media_id={}
[loginfo]
#日志目录
logdir_name = logdir
#日志文件名称
logfile_name = wechat_server.log
三、测试
在企业微信发送消息,可以修改配置文件制定转发到特定的群组,从而避免消息分流。
启用应用API,设置回调地址
测试发送消息
查看接受消息
四、优化
  • 后期可以配合数据库将每次获取的access_token 保存至数据库,待2小时过期后,再重新获取新的。
  • 更多内容转发
【生长吧!Python】有奖征文火热进行中:https://bbs.huaweicloud.cn/blogs/278897
