mac 安装es
Nick Qiu 发表于 2021/06/13 21:14:53 2021/06/13
【摘要】 mac安装es 安装步骤wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.13.1-darwin-x86_64.tar.gzwget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.13.1-darwin...
mac安装es
简介
本文讲解如何在mac内安装es,并且配置密码增强es的安全性
安装步骤
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.13.1-darwin-x86_64.tar.gz.sha512
shasum -a 512 -c elasticsearch-7.13.1-darwin-x86_64.tar.gz.sha512
tar -xzf elasticsearch-7.13.1-darwin-x86_64.tar.gz
# 该路径是变量$ES_HOME的路径
cd elasticsearch-7.13.1/
#  启动es
./bin/elasticsearch
#  后台启动es,记录进程的pid到文件pid内
./bin/elasticsearch -d -p pid
# 验证es是否正常安装,如下命令返回集群的信息
curl localhost:9200
## 返回信息如下:
  "name" : "Cp8oag6",
  "cluster_name" : "elasticsearch",
  "cluster_uuid" : "AT69_T_DTp-1qgIJlatQqA",
  "version" : {
    "number" : "7.13.1",
    "build_flavor" : "default",
    "build_type" : "tar",
    "build_hash" : "f27399d",
    "build_date" : "2016-03-30T09:51:41.449Z",
    "build_snapshot" : false,
    "lucene_version" : "8.8.2",
    "minimum_wire_compatibility_version" : "1.2.3",
    "minimum_index_compatibility_version" : "1.2.3"
  "tagline" : "You Know, for Search"
# 关闭es
pkill -F pid
配置密码
  • 关闭es和kibana
  • 进入es的安装目录,修改配置文件vim ES_PATH_CONF/elasticsearch.yml
# 使能xpack的基本安全功能
xpack.security.enabled: true
# option 如果集群只有一个节点,则添加入下配置
# discovery.type: single-node
  • 为默认用户配置密码
# 进入es目录,重新启动ES
./bin/elasticsearch
# ES中内置了几个管理账号即:apm_system, beats_system, elastic, kibana, logstash_system, remote_monitoring_user,使用之前,首先需要添加一下密码。新打开一个窗口,执行如下命令配置密码``cd ES_INSTALL_PATH``,如下选择一个方式配置密码
./bin/elasticsearch-setup-passwords auto    # 自动生成密码
Changed password for user apm_system
PASSWORD apm_system = RIuNWv5xEVGGc0CqLKGZ
Changed password for user kibana_system
PASSWORD kibana_system = mOe4zLy838VfMSKZK4kn
PASSWORD kibana = mOe4zLy838VfMSKZK4kn
Changed password for user logstash_system
PASSWORD logstash_system = Q2tpES4Mh72hArtOZRuO
Changed password for user beats_system
PASSWORD beats_system = 3cByriDjcz5ziIH0roxt
Changed password for user remote_monitoring_user
PASSWORD remote_monitoring_user = zSY1JnyHYZQhWLosRbZ6
Changed password for user elastic
PASSWORD elastic = DeXac7bdHt45OGSyTtsQ
./bin/elasticsearch-setup-passwords interactive     # 用户交互输入密码
  • 配置kibana,进入kibana目录,修改配置文件KIB_PATH_CONF/kibana.yml,去掉如下行的注释
elasticsearch.username: "kibana_system"
  • 创建 Kibana keystore
./bin/kibana-keystore create
  • 添加密码到keystore文件
# 输入该命令之后再输入``kibana_system``的密码
./bin/kibana-keystore add elasticsearch.password
  • 重新启动kibana
./bin/kibana
# 添加对象类型
curl -X PUT 'http://elastic:DeXac7bdHt45OGSyTtsQ@localhost:9200/student/_doc/3' -H "Content-Type: application/json" -d '
  "name": "张三",
  "age_range": {
    "gte": 5,
    "lte": 25
  "address": {
    "contry": "China",
    "location": {
      "province": "广东",
      "city": "深圳"
# 查询数据
curl -X POST 'http://elastic:DeXac7bdHt45OGSyTtsQ@localhost:9200/student/_search' -H "Content-Type: application/json" -d '
  "query":{
    "match": {
      "address.location.city": "深圳"
# 查询数据
curl -X GET "http://elastic:DeXac7bdHt45OGSyTtsQ@localhost:9200/student/_doc/3?pretty"
