Springboot整合cxf进行WebService发布和WebService调用
陈皮的JavaLib 发表于 2021/06/10 23:10:37 2021/06/10
【摘要】 1:添加依赖 Maven工程: <dependency> <groupId>org.apache.cxf</groupId> <artifactId>cxf-spring-boot-starter-jaxws</artifactId> <version>3.3.3</version>...
1:添加依赖
Maven工程:
<dependency>
</dependency>
Gradle工程:
'org.apache.cxf:cxf-spring-boot-starter-jaxws:3.3.3'
2:服务端接口
package com.nobody.service;
import javax.jws.WebMethod;
import javax.jws.WebParam;
import javax.jws.WebResult;
import javax.jws.WebService;
 * 测试接口
 * @author Μr.ηobοdy
 * @date 2019-12-29
@WebService(name = "UserService", // 暴露服务名称 targetNamespace = "http://service.nobody.com" // 命名空间,一般是接口的包名倒序
public interface UserService { @WebMethod @WebResult(name = "String", targetNamespace = "") String addUser(@WebParam(name = "username") String username, @WebParam(name = "age") int age);
3:服务端接口实现
package com.nobody.service.impl;
import org.springframework.stereotype.Component;
import com.nobody.service.UserService;
 * 测试接口实现
 * @author Μr.ηobοdy
 * @date 2019-12-29
@WebService(serviceName = "UserService", // 与接口中指定的name一致 targetNamespace = "http://service.nobody.com", // 与接口中的命名空间一致,一般是接口的包名倒 endpointInterface = "com.nobody.service.UserService" // 接口地址
@Component
public class UserServiceImpl implements UserService { @Override public String addUser(String username, int age) { return "Add user success,username:" + username + ",age:" + age; }
  • 26
  • 27
  • 28
  • 29
  • 30
4:CXF配置
package com.nobody.config;
import javax.xml.ws.Endpoint;
import org.apache.cxf.Bus;
import org.apache.cxf.jaxws.EndpointImpl;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
 * cxf配置
 * @author Μr.ηobοdy
 * @date 2019-12-29
@Configuration
public class CxfConfig { @Autowired private Bus bus; @Autowired private UserService userService; @Bean public Endpoint endpoint() { EndpointImpl endpoint = new EndpointImpl(bus, userService); endpoint.publish("/UserService"); return endpoint; }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
5:wsdl文件
默认服务在host:port/工程服务名/services/所在的路径下。因为本工程没设置服务名,故此接口发布路径为/services/UserService,wsdl文件路径为:
http://localhost:8080/services/UserService?wsdl
服务启动后,在浏览器输入以上地址即可看到wsdl文件:
6:客户端调用
package com.nobody.controller;
import org.apache.cxf.endpoint.Client;
import org.apache.cxf.jaxws.endpoint.dynamic.JaxWsDynamicClientFactory;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RequestParam;
@RestController
@RequestMapping("demo")
public class DemoController { @GetMapping("test") public String test(@RequestParam String username, @RequestParam int age) { String result = null; // 创建动态客户端 JaxWsDynamicClientFactory dcf = JaxWsDynamicClientFactory.newInstance(); Client client = dcf.createClient("http://localhost:8080/services/UserService?wsdl"); // 如果需要密码时加上用户名和密码 // client.getOutInterceptors().add(new ClientLoginInterceptor(USERNAME,PASSWORD)); // 接受返回值对象 Object[] objects = new Object[0]; try { // 调用 objects = client.invoke("addUser", username, age); result = "调用webservice接口返回数据:" + objects[0]; } catch (Exception e) { e.printStackTrace(); } return result; }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
7:启动工程,在浏览器输入以下地址即可进行调用
http://127.0.0.1:8080/demo/test?username=Mr.nobody&age=18
返回结果:
8:项目Github下载地址
Springboot整合cxf使用WebService
文章来源: javalib.blog.csdn.net,作者:陈皮的JavaLib,版权归原作者所有,如需转载,请联系作者。
原文链接:javalib.blog.csdn.net/article/details/103758269
