@Value注解不能注入static修饰的属性
陈皮的JavaLib 发表于 2021/06/10 00:49:49 2021/06/10
【摘要】 1:问题描述 配置文件application.yml: person.name: nobody person.age: 20 12 实体类Person: package com.nobody.pojo.entity; import java.io.Serializable; import org.springframework.beans.factory.a...
1:问题描述
person.name: nobody
person.age: 20
实体类Person:
import org.springframework.beans.factory.annotation.Value;
import org.springframework.stereotype.Component;
@Component
public class Person implements Serializable { /** * */ private static final long serialVersionUID = -8245392957106320519L; @Value("${person.name}") private static String name; private static String age; @Value("${person.age}") public void setAge(String age) { Person.age = age; } public void setName(String name) { Person.name = name; } public static String getName() { return name; } public static String getAge() { return age; }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
测试接口类DemoController:
package com.nobody.controller;
import org.springframework.web.bind.annotation.RequestMapping;
import com.nobody.ehr.pojo.entity.Person;
@RequestMapping("demo")
@RestController
public class DemoController { @GetMapping public String demo() { System.out.println("name:" + Person.getName() + ", age:" + Person.getAge()); return ""; }
测试结果:
@Value注解放在属性上注入值失败,而@Value放在setter方法上(注意,该方法也不能是静态方法)注入成功。
2:分析
启动日志:
[19:37:45] INFO  [restartedMain] o.s.b.f.a.AutowiredAnnotationBeanPostProcessor - Autowired annotation is not supported on static fields: private static java.lang.String com.nobody.pojo.entity.Person.name
源码分析:
private InjectionMetadata buildAutowiringMetadata(final Class<?> clazz) {
		List<InjectionMetadata.InjectedElement> elements = new ArrayList<>();
		Class<?> targetClass = clazz; do { final List<InjectionMetadata.InjectedElement> currElements = new ArrayList<>(); ReflectionUtils.doWithLocalFields(targetClass, field -> { AnnotationAttributes ann = findAutowiredAnnotation(field); if (ann != null) { //这里对静态属性注入做了过滤 if (Modifier.isStatic(field.getModifiers())) { if (logger.isInfoEnabled()) { logger.info("Autowired annotation is not supported on static fields: " + field); } return; } boolean required = determineRequiredStatus(ann); currElements.add(new AutowiredFieldElement(field, required)); } }); ReflectionUtils.doWithLocalMethods(targetClass, method -> { Method bridgedMethod = BridgeMethodResolver.findBridgedMethod(method); if (!BridgeMethodResolver.isVisibilityBridgeMethodPair(method, bridgedMethod)) { return; } AnnotationAttributes ann = findAutowiredAnnotation(bridgedMethod); if (ann != null && method.equals(ClassUtils.getMostSpecificMethod(method, clazz))) { //这里对静态方法做了过滤 if (Modifier.isStatic(method.getModifiers())) { if (logger.isInfoEnabled()) { logger.info("Autowired annotation is not supported on static methods: " + method); } return; } if (method.getParameterCount() == 0) { if (logger.isInfoEnabled()) { logger.info("Autowired annotation should only be used on methods with parameters: " + method); } } boolean required = determineRequiredStatus(ann); PropertyDescriptor pd = BeanUtils.findPropertyForMethod(bridgedMethod, clazz); currElements.add(new AutowiredMethodElement(method, required, pd)); } }); elements.addAll(0, currElements); targetClass = targetClass.getSuperclass();
		while (targetClass != null && targetClass != Object.class); return new InjectionMetadata(clazz, elements);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
3:结论
从源码上发现,理论上spring是可以对静态域注入的,只是spring没有这样做,它认为依赖注入发生的时段是在实例的生命周期,而不是类的生命周期。
文章来源: javalib.blog.csdn.net,作者:陈皮的JavaLib,版权归原作者所有,如需转载,请联系作者。
原文链接:javalib.blog.csdn.net/article/details/105229998
