insightface 切换GPU训练报错解决
风吹稻花香 发表于 2021/06/08 23:34:57 2021/06/08
【摘要】 insightface代码: https://github.com/deepinsight/insightface 在pytorch训练时,先用gpu1训练,再用gpu2训练,加载gpu1的预训练时报错, 解决方法: 先用cpu加载模型,再转换到新的gpu id上, 代码如下: self.weight: torch.Tensor = torch.load(sel...
insightface代码:
解决方法:
代码如下:
  1. self.weight: torch.Tensor = torch.load(self.weight_name,map_location='cpu')
  2. self.weight=self.weight.cuda(local_rank)
  3. self.weight_mom: torch.Tensor = torch.load(self.weight_mom_name,map_location='cpu')
  4. self.weight_mom=self.weight_mom.cuda(local_rank)
partial_fc.py 完整代码如下:
  1. import logging
  2. import os
  3. import torch
  4. import torch.distributed as dist
  5. from torch.nn import Module
  6. from torch.nn.functional import normalize, linear
  7. from torch.nn.parameter import Parameter
  8. class PartialFC(Module):
  9. """
  10. Author: {Xiang
原文链接:blog.csdn.net/jacke121/article/details/117703681
