PHP编译遇到的问题
互联网老辛 发表于 2021/06/08 22:57:51 2021/06/08
【摘要】 编译php的时候遇到的问题: 编译代码: ./configure --prefix=/server/php-5.4-nginx --with-config-file-path=/server/php-5.4-nginx --with-mysql=/server/mysql-5.5/ --with-mysqli=/server/mysql-5.5/bin/mysql_co...
编译php的时候遇到的问题:
编译代码:
./configure --prefix=/server/php-5.4-nginx --with-config-file-path=/server/php-5.4-nginx --with-mysql=/server/mysql-5.5/ --with-mysqli=/server/mysql-5.5/bin/mysql_config --with-iconv-dir --with-freetype-dir --with-jpeg-dir --with-png-dir --with-zlib --with-libxml-dir=/usr --enable-xml --disable-rpath --enable-safe-mode --enable-bcmath --enable-shmop --enable-sysvsem --enable-inline-optimization --with-curl --with-curlwrappers --enable-mbregex --enable-fpm --enable-mbstring  --with-gd --enable-gd-native-ttf --with-openssl --with-mhash --enable-pcntl --enable-sockets  --with-xmlrpc --enable-zip --enable-soap  --with-mcrypt=/usr/local/
报错信息:configure: error: Please reinstall the libcurl distribution -
    easy.h should be in <curl-dir>/include/curl/
解决办法:yum install curl-devel
再次编译报错:
configure: error: jpeglib.h not found.
解决方法:
检查之后发现已经安装了libjpeg
[root@localhost php-5.2.14]# yum list installed|grep libpng
libpng.x86_64           2:1.2.49-1.el6_2
或者:
[root@localhost php-5.2.14]# rpm -qa|grep libjpeg
libjpeg-turbo-1.2.1-3.el6_5.x86_64
如果没有安装则需要:
yum install libjpeg libpng freetype libjpeg-devel libpng-devel freetype-devel -y
若是64位系统
解决方法:
yum install libjpeg.x86_64 libpng.x86_64 freetype.x86_64 libjpeg-devel.x86_64 libpng-devel.x86_64 freetype-devel.x86_64 -y
安装完后再安装libjpeg-devel
安装libjpeg-devel
yum -y install libjpeg-devel
记住一点就好了:编译过程中出现错误不可怕,出现一个解决一个就好了。
本文出自 “xinsz08の平行时空” 博客,请务必保留此出处http://xinsz08.blog.51cto.com/10565212/1795763
文章来源: zmedu.blog.csdn.net,作者:互联网老辛,版权归原作者所有,如需转载,请联系作者。
原文链接:zmedu.blog.csdn.net/article/details/77414617
