【庖丁解牛】configure: error: Please reinstall the libzip distribution
互联网老辛 发表于 2021/06/08 23:39:40 2021/06/08
【摘要】 问题复现 重新编译php报错 configure: error: Please reinstall the libzip distribution 使用yum安装无效 [root@xinsz08 php-7.3.6]# yum install libzip Loaded plugins: fastestmirror Loading mirror speeds f...
问题复现
重新编译php报错
使用yum安装无效
Loading mirror speeds from cached hostfile
Package libzip-0.10.1-8.el7.x86_64 already installed and latest version
Nothing to do
问题解决
下载新版本
[root@xinsz08 php-7.3.6]# curl -O https://libzip.org/download/libzip-1.5.2.tar.gz
  % Total % Received % Xferd  Average Speed   Time Time Time  Current Dload  Upload   Total   Spent Left  Speed
[root@xinsz08 ~]# tar xf libzip-1.5.2.tar.gz
[root@xinsz08 ~]# cd libzip-1.5.2
[root@xinsz08 bulid]# yum install cmake
[root@xinsz08 bulid]# mkdir bulid
[root@xinsz08 bulid]# cd bulid/
[root@xinsz08 bulid]# yum remove libzip
cmake版本也会出现过低的情况:
下载cmake
root@xinsz08 bulid]# wget https://cmake.org/files/v3.18/cmake-3.18.0-Linux-x86_64.sh
[root@xinsz08 ~]# chmod 777 cmake-3.18.0-Linux-x86_64.sh   ## 加权限
卸载掉原来的cmake
[root@xinsz08 ~]# yum remove cmake
执行脚本安装新的
[root@xinsz08 ~]# ./cmake-3.18.0-Linux-x86_64.sh
进入build目录
[root@xinsz08 libzip-1.5.2]# cd bulid/
[root@xinsz08 bulid]# ls
cmake-3.18.0-Linux-x86_64.sh  CMakeCache.txt  CMakeFiles
执行cmake
做软连接
[root@xinsz08 bulid]# ln -s /home/zmedu/cmake-3.18.0-Linux-x86_64/bin/cmake /usr/bin/cmake
编译
[root@xinsz08 bulid]# cmake ..
[root@xinsz08 bulid]# make
[root@xinsz08 bulid]# make install
安装成功后,继续编译php7
文章来源: zmedu.blog.csdn.net,作者:互联网老辛,版权归原作者所有,如需转载,请联系作者。
原文链接:zmedu.blog.csdn.net/article/details/107550083
