【shell案例】nginx编译安装脚本
互联网老辛 发表于 2021/06/09 01:18:15 2021/06/09
【摘要】 前言 本脚本没有使用函数,脚本安装的是nginx-1.16.1 , 如果你要安装其他版本,可以适当修改脚本的版本号 sed -i ‘s/原字符串/新字符串/g’ /app/nginx-install.sh 注意: 此脚本名字为nginx-install.sh, 存放在/app路径下: 脚本源码 #!/bin/bash systemctl stop firewall...
前言
脚本源码
#!/bin/bash
systemctl stop firewalld && setenforce 0
#首先安装nginx的依赖环境
yum -y install gcc pcre-devel zlib-devel net-tools wget
#解压nginx的安装包
if [ ! -d "/root/nginx-1.16.1" ]; then wget http://nginx.org/download/nginx-1.16.1.tar.gz tar -zxf nginx-1.16.1.tar.gz echo "压缩包已解压"
else echo "此文件已存在" continue
fi
#进去文件开始检查环境 编译安装
if [ ! -d /usr/local/nginx ]; then cd /root/nginx-1.16.1 && ./configure --prefix=/usr/local/nginx --user=nginx --group=nginx --with-http_ssl_module --with-http_stub_status_module
  && make && make install
else continue
fi
#判断是否nginx的端口被占用
pid_file="/usr/local/nginx/logs/nginx.pid"
if [ ! -e ${pid_file} ]; then echo "被占用的pid是:`cat ${pid_file}`" kill `cat ${pid_file}` echo "服务被占用,已删掉"
else echo "服务没有被占用" continue
fi
nginx=/usr/local/nginx/sbin/nginx
#开始启动nginx
read -p "接下来要做的操作:" action
check(){ netstat -anptu | grep nginx if [ $? -eq 0 ];then continue fi
case $action in start) netstat -anptu | grep nginx if [ $? -eq 0 ]; then continue else $nginx fi ;; stop) netstat -anptu | grep nginx if [ $? -eq 0 ]; then echo "nginx-server is already running  nginx-server begin stop" $nginx -s stop else echo "nginx-server is not start" fi ;; reload) netstat -anptu | grep nginx if [ $? -eq 0 ]; then echo "nginx-server is already running  nginx-server begin reload" $nginx -s reload else echo "nginx-server is not running now begin start nginx-server" $nginx $nginx -s reload fi ;; statue) check ;; *) echo "please enter{start|stop|reload|statue}" ;;
esac
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
脚本重要练习,在不断练习中成长。
文章来源: zmedu.blog.csdn.net,作者:互联网老辛,版权归原作者所有,如需转载,请联系作者。
原文链接:zmedu.blog.csdn.net/article/details/108186211
