初始化kubernetes端口占用问题
互联网老辛 发表于 2021/06/08 22:40:48 2021/06/08
【摘要】 执行 命令: [root@oldxin-master17 ~]# kubeadm init --apiserver-advertise-address=192.168.1.17 --image-repository registry.aliyuncs.com/google_containers --kubernetes-version v1.20.5 --service...
执行 命令:
[root@oldxin-master17 ~]# kubeadm init --apiserver-advertise-address=192.168.1.17 --image-repository registry.aliyuncs.com/google_containers --kubernetes-version v1.20.5 --service-cidr=10.96.0.0/12 --pod-network-cidr=10.244.0.0/16
发生报错信息:
原报错:
[WARNING IsDockerSystemdCheck]: detected "cgroupfs" as the Docker cgroup driver. The recommended driver is "systemd". Please follow the guide at https://kubernetes.io/docs/setup/cri/
error execution phase preflight: [preflight] Some fatal errors occurred:
	[ERROR Port-6443]: Port 6443 is in use
	[ERROR Port-10259]: Port 10259 is in use
	[ERROR Port-10257]: Port 10257 is in use
初步判定为端口占用,杀死进程
解决方案:
尝试杀死进程都没有用,最终重启一下kubeadm就可以了,如下:
[root@k8s-master01 ~]# kubeadm reset
文章来源: zmedu.blog.csdn.net,作者:互联网老辛,版权归原作者所有,如需转载,请联系作者。
原文链接:zmedu.blog.csdn.net/article/details/115060315
