C# 反射(二)
MICAR 发表于 2021/06/08 16:32:02 2021/06/08
【摘要】 实例在本实例中,将使用在之前创建的 DeBugInfo 特性,并使用反射(Reflection)来读取 Rectangle 类中的元数据。实例using System;using System.Reflection;namespace BugFixApplication{   // 一个自定义特性 BugFix 被赋给类及其成员   [AttributeUsage(AttributeTarg...
实例
实例
using System;
   [AttributeUsage(AttributeTargets.Class |
   AttributeTargets.Constructor |
   AttributeTargets.Field |
   AttributeTargets.Method |
   AttributeTargets.Property,
   AllowMultiple = true)]
   public class DeBugInfo : System.Attribute
      private int bugNo;
      private string developer;
      private string lastReview;
      public string message;
      public DeBugInfo(int bg, string dev, string d)
         this.bugNo = bg;
         this.developer = dev;
         this.lastReview = d;
      public int BugNo
         get
            return bugNo;
      public string Developer
         get
            return developer;
      public string LastReview
         get
            return lastReview;
      public string Message
         get
            return message;
         set
            message = value;
   [DeBugInfo(45, "Zara Ali", "12/8/2012",
        Message = "Return type mismatch")]
   [DeBugInfo(49, "Nuha Ali", "10/10/2012",
        Message = "Unused variable")]
   class Rectangle
      // 成员变量
      protected double length;
      protected double width;
      public Rectangle(double l, double w)
         length = l;
         width = w;
      [DeBugInfo(55, "Zara Ali", "19/10/2012",
      public double GetArea()
         return length * width;
      [DeBugInfo(56, "Zara Ali", "19/10/2012")]
      public void Display()
         Console.WriteLine("Length: {0}", length);
         Console.WriteLine("Width: {0}", width);
         Console.WriteLine("Area: {0}", GetArea());
   }//end class Rectangle
   class ExecuteRectangle
      static void Main(string[] args)
         Rectangle r = new Rectangle(4.5, 7.5);
         r.Display();
         Type type = typeof(Rectangle);
         // 遍历 Rectangle 类的特性
         foreach (Object attributes in type.GetCustomAttributes(false))
            DeBugInfo dbi = (DeBugInfo)attributes;
            if (null != dbi)
               Console.WriteLine("Bug no: {0}", dbi.BugNo);
               Console.WriteLine("Developer: {0}", dbi.Developer);
               Console.WriteLine("Last Reviewed: {0}",
                                        dbi.LastReview);
               Console.WriteLine("Remarks: {0}", dbi.Message);
         // 遍历方法特性
         foreach (MethodInfo m in type.GetMethods())
            foreach (Attribute a in m.GetCustomAttributes(true))
               DeBugInfo dbi = (DeBugInfo)a;
               if (null != dbi)
                  Console.WriteLine("Bug no: {0}, for Method: {1}",
                                                dbi.BugNo, m.Name);
                                                dbi.LastReview);
         Console.ReadLine();
当上面的代码被编译和执行时,它会产生下列结果:
Length: 4.5
Width: 7.5
Area: 33.75
Bug No: 49
Developer: Nuha Ali
Last Reviewed: 10/10/2012
Remarks: Unused variable
Bug No: 45
Developer: Zara Ali
Last Reviewed: 12/8/2012
Remarks: Return type mismatch
Bug No: 55, for Method: GetArea
Developer: Zara Ali
Last Reviewed: 19/10/2012
Bug No: 56, for Method: Display
Developer: Zara Ali
Remarks:
