VFloss pytorch
【摘要】
# Loss functions import torchimport torch.nn as nn from utils.general import bbox_ioufrom utils.torch_utils import is_parallel def smooth_BCE(eps=0.1): # https://github.com/ultral...
# Loss functions
import torch
def smooth_BCE(eps=0.1): # https://github.com/ultralytics/yolov3/issues/238#issuecomment-598028441
# return positive, negative label smoothing BCE targets
return 1.0 - 0.5 * eps, 0.5 * eps
class BCEBlurWithLogitsLoss(nn.Module):
# BCEwithLogitLoss() with reduced missing label effects.
def __init__(self, alpha=0.05):
super(BCEBlurWithLogitsLoss, self).__init__()
self.loss_fcn = nn.BCEWithLogitsLoss(reduction='none') # must be nn.BCEWithLogitsLoss()
self.alpha = alpha
def forward(self, pred, true):
loss = self.loss_fcn(pred, true)
pred = torch.sigmoid(pred) # prob from logits
dx = pred - true # reduce only missing label effects
# dx = (pred - true).abs() # reduce missing label and false
原文链接:blog.csdn.net/jacke121/article/details/117637195
cloudbbs@huaweicloud.com
