c# 启动控制台
风吹稻花香 发表于 2021/06/05 22:31:12 2021/06/05
【摘要】   namespace 测试使用 {     public partial class Form1 : Form { [System.Runtime.InteropServices.DllImport("kernel32.dll", SetLastError = true)] [return: System.Runtime.InteropS...
复制代码
namespace 测试使用
{     public partial class Form1 : Form { [System.Runtime.InteropServices.DllImport("kernel32.dll", SetLastError = true)] [return: System.Runtime.InteropServices.MarshalAs(System.Runtime.InteropServices.UnmanagedType.Bool)] static extern bool AllocConsole(); [System.Runtime.InteropServices.DllImport("Kernel32")] public static extern void FreeConsole(); public Form1() { InitializeComponent(); } private void Form1_Load(object sender, EventArgs e) { AllocConsole();   //开启控制台 } }
复制代码
输出一
通常的代码段: Console.WriteLine(“测试”);
效果显示:
输出二:
创建方法类来进行输出
           Shell.WriteLine("注意:启动程序...");
            Shell.WriteLine("\tWritten by wuming");
            Shell.WriteLine("{0}:{1}", "警告", "这是一条警告信息。");
            Shell.WriteLine("{0}:{1}", "错误", "这是一条错误信息!");
            Shell.WriteLine("{0}:{1}", "注意", "这是一条需要的注意信息。");
            Shell.WriteLine("");
           Shell.WriteLine("测试",ConsoleColor.DarkRed);
复制代码
  static class Shell
    { /// <summary>   /// 输出信息   /// </summary>   /// <param name="format"></param>   /// <param name="args"></param>   public static void WriteLine(string message, ConsoleColor GetConsoleColor) { Console.ForegroundColor = GetConsoleColor; Console.WriteLine(@"[{0}]{1}", DateTimeOffset.Now, message); }         /// <summary>
        /// 输出信息
        /// </summary>
        public static void WriteLine(string format, params object[] args)
            WriteLine(string.Format(format, args));
        /// <summary>
        /// 输出信息
        /// </summary>
        /// <param name="output"></param>
        public static void WriteLine(string output)
            Console.ForegroundColor = GetConsoleColor(output);
            Console.WriteLine(@"[{0}]{1}", DateTimeOffset.Now, output);
        /// <summary>
        /// 根据输出文本选择控制台文字颜色
        /// </summary>
        /// <returns></returns>
        private static ConsoleColor GetConsoleColor(string output)
            if (output.StartsWith("警告")) return ConsoleColor.Yellow;
            if (output.StartsWith("错误")) return ConsoleColor.Red;
            if (output.StartsWith("注意")) return ConsoleColor.Green;
            return ConsoleColor.Gray;
原文链接:blog.csdn.net/jacke121/article/details/103361511
