yolov5 tensorrt
风吹稻花香 发表于 2021/06/06 00:40:27 2021/06/06
【摘要】   python tensorrt: 激活函数:hard_sigmoid https://github.com/TrojanXu/yolov5-tensorrt   https://github.com/wang-xinyu/tensorrtx The Pytorch implementation is ultralytics/yol...
python tensorrt:
激活函数:hard_sigmoid
The Pytorch implementation is ultralytics/yolov5.
Currently, we support yolov5 v1.0(yolov5s only), v2.0, v3.0 and v3.1.
Config
  • Choose the model s/m/l/x by NET macro in yolov5.cpp
  • Input shape defined in yololayer.h
  • Number of classes defined in yololayer.h, DO NOT FORGET TO ADAPT THIS, If using your own model
  • FP16/FP32 can be selected by the macro in yolov5.cpp
  • GPU id can be selected by the macro in yolov5.cpp
  • NMS thresh in yolov5.cpp
  • BBox confidence thresh in yolov5.cpp
  • Batch size in yolov5.cpp
v2也是leakyrelu。
2.0:这个是匹配3.0的版本,用的leakyrelu,可以检测,v3.0自己训练的精度比较低
https://github.com/BaofengZan/yolov5_2.0-TensorRt
https://github.com/AIpakchoi/yolov5_tensorrt/blob/110762eea4a7a53a91bbce35f94239136db157d4/yolov5l/common.hpp
https://github.com/baituhuangyu/yolov5-tensorrt
https://github.com/Thinker-or-Dreamer/UAV-And-RobotArm/tree/master/yolov5
HardSwishLayer_TRT
https://github.com/hlld/tensorrt-yolov5
c++不知道哪个版本:
https://github.com/enazoe/yolo-tensorrt
2020.10.23 17天以前更新的,激活函数:kHARD_SIGMOID
https://github.com/wang-xinyu/tensorrtx/tree/master/yolov5
yololayer.h
修改自己类别个数:
    static constexpr int CLASS_NUM = 1;
下面是阈值参数,nms阈值参数:
  1. #define USE_FP16 // comment out this if want to use FP32
  2. #define DEVICE 0 // GPU id
  3. #define NMS_THRESH 0.4
  4. #define CONF_THRESH 0.3
  5. std::cerr << "yolov5_rt.exe -s s // serialize model to plan file" << std::endl;
  6. std::cerr << "yolov5_rt.exe -e s -c 0 // detect cam" << std::endl;
  7. std::cerr << "yolov5_rt.exe -e s -d samples // deserialize plan file and run inference" << std::endl;
后面3行是调用demo,分两步,编译和执行
问题:原版网络检测出来的框没问题
自己训练的,tensorrt检测的与pytorch检测出来的有偏差,原因还未找到。
可能是anchors的原因,但是没找到证据。
原文链接:blog.csdn.net/jacke121/article/details/109233756
