pytorch 加载模型:
风吹稻花香 发表于 2021/06/05 23:33:14 2021/06/05
【摘要】 1.直接加载网络 import torch pthfile = r'E:\anaconda\app\envs\luo\Lib\site-packages\torchvision\models\squeezenet1_1.pth' net = torch.load(pthfile) print(net)   import torch def remove...
1.直接加载网络
import torch
print(net)
  1. import torch
  2. def remove_prefix(state_dict, prefix):
  3. ''' Old style model is stored with all names of parameters
  4. share common prefix 'module.' '''
  5. # logger.info('remove prefix \'{}\''.format(prefix))
  6. f = lambda x: x.split(prefix, 1)[-1] if x.startswith(prefix) else x
  7. return {f(key): value for key, value in state_dict.items()}
  8. def load_model(model, pretrained_path, load_to_cpu):
  9. print('Loading pretrained model from {}'.format(pretrained_path))
  10. if load_to_cpu:
  11. pretrained_dict = torch.load(pretrained_path, map_location=lambda storage, loc: storage)
  12. else:
  13. device = torch.cuda.current_device()
  14. pretrained_dict =
原文链接:blog.csdn.net/jacke121/article/details/105229678
