DataParallel 笔记
风吹稻花香 发表于 2021/06/05 22:48:03 2021/06/05
【摘要】 单GPU: import os os.environ["CUDA_VISIBLE_DEVICES"] = "0" 多GPU: device_ids = [0,1,2,3] model = model.cuda(device_ids[0]) model = nn.DataParallel(model, device_ids=device_ids) optimizer = o...
单GPU:
import os
多GPU:
optimizer = optim.SGD(model.parameters(), lr=learning_rate, momentum=0.9, weight_decay=0.001)
optimizer = nn.DataParallel(optimizer, device_ids=device_ids)
optimizer.module.step()
for param_lr in optimizer.module.param_groups:  # 同样是要加module
        #     param_lr['lr'] = param_lr['lr'] * 0.999
加载多GPU预训练模型
model = ft_net()
pretained_model = torch.load('./model/all/8_model.pkl')
pretained_dict = pretained_model.module.state_dict()
model = ft_net()
model.load_state_dict(pretained_dict)
if torch.cuda.device_count() > 1:#判断是不是有多个GPU
原文链接:blog.csdn.net/jacke121/article/details/108806050
