oracle group by用法
风吹稻花香 发表于 2021/06/05 01:59:14 2021/06/05
【摘要】 分组第一个: SELECT * FROM (SELECT ROW_NUMBER() OVER(PARTITION BY dlr_id ORDER BY user_id DESC) rn,   u.user_id,u.dlr_id FROM tm_user u where dlr_id='1000001812')   WHERE rn = 1  ; sele...
分组第一个:
  WHERE rn = 1  ;
select user_id,dlr_id from tm_user tu where tu.rowid in (
select max(rowid) from(
select user_id,dlr_id from tm_user)
group by dlr_id) and dlr_id='1000001812';
Oracle分组排名
情境:只查询某个条件下的N条件记录,如每个分类下查询(前)5条
例:(相同商户号只查5条)
[sql] view plaincopy
    select *
      from (select t.mer_code,
                   t.li_goods_name,
                   t.li_id,
                   dense_rank() over(partition by t.mer_code order by t.li_id) rk
              from yd_mer_listing t)
     where rk < 6
说明:rank()的排名是按over()内order by决定的,如果order by的字段值是一样的,那么rank()排名也一样。
优势:如果用in语句,如 … where t.li_id in (select LI_ID from yd_mer_listing m where rownum < 6 and m.mer_code = t.mer_code and m.LI_STATE = '3' )…效率会很低
原文链接:blog.csdn.net/jacke121/article/details/54429549
