matlab转c++
风吹稻花香 发表于 2021/06/04 23:59:18 2021/06/04
【摘要】 资源地址: https://github.com/jonathf/matlab2cpp sudo python setup.py install sudo pip install setuptools sudo -s pip install sphinxpip install sphinxcontrib-autoprogrampip inst...
资源地址:
sudo -s
  1. pip install sphinx
  2. pip install sphinxcontrib-autoprogram
  3. pip install sphinxcontrib-napoleon
  4. pip install sphinx-argparse
Argcomplete::
  1. pip install argcomplete
  2. activate-global-python-argcomplete
用法:
$ m2cpp example.m
This will create two files: example.m.hpp and example.m.py.
$ m2cpp example.m -s
The file example.m.py will then automatically be populated with data typesfrom context::
这个是java版的:
https://github.com/clwade/Matlab2C
原文链接:blog.csdn.net/jacke121/article/details/56950710
