php-curl
风吹稻花香 发表于 2021/06/04 23:18:14 2021/06/04
【摘要】 use anlutro\cURL\cURL; $curl = new cURL; $post_data= array ("sname" => "dlrmcf58", "spwd" => "ZRB2aP8K", "scorpid" => "1", "sprdid" => 11,"sdst" => 18601924901, "smsg...
$curl = new cURL;
"scorpid" => "1",
"smsg" => rawurlencode("zhuce")
//$response = $curl->post("http://cf.lmobile.cn/submitdata/Service.asmx/g_Submit","sname=dlrmcf58&spwd=ZRB2aP8K&scorpid=&sprdid=100&sdst=18601924901&smsg=".rawurlencode("zhuce"));
$response = $curl->post("http://cf.lmobile.cn/submitdata/Service.asmx/g_Submit",$post_data);
 echo $response ;
https://github.com/anlutro/php-curl
 composer require anlutro/curl
Optionally, add 'cURL' => 'anlutro\cURL\Laravel\cURL' to the array of aliases in config/app.php.
Usage
$curl = new anlutro\cURL\cURL;
$response = $curl->get('http://www.google.com');
// easily build an url with a query string
$url = $curl->buildUrl('http://www.google.com', ['s' => 'curl']);
$response = $curl->get($url);
// the post, put and patch methods takes an array of POST data
$response = $curl->post($url, ['api_key' => 'my_key', 'post' => 'data']);
// add "json" to the start of the method to convert the data to a JSON string
// and send the header "Content-Type: application/json"
$response = $curl->jsonPost($url, ['post' => 'data']);
// if you don't want any conversion to be done to the provided data, for example
// if you want to post an XML string, add "raw" to the start of the method
$response = $curl->rawPost($url, '<?xml version...');
// raw request are also the easiest way to upload files
$file = curl_file_create('/path/to/file');
$response = $curl->rawPost($url, ['file' => $file]);
// a response object is returned
var_dump($response->statusCode); // response status code integer (for example, 200)
var_dump($response->statusText); // full response status (for example, '200 OK')
echo $response->body;
var_dump($response->headers); // array of headers
var_dump($response->info); // array of curl info
If you need to send headers or set cURL options you can manipulate a request object directly. send() finalizes the request and returns the result.
// newRequest, newJsonRequest and newRawRequest returns a Request object
$request = $curl->newRequest('post', $url, ['foo' => 'bar'])
    ->setHeader('Accept-Charset', 'utf-8')
    ->setHeader('Accept-Language', 'en-US')
    ->setOption(CURLOPT_CAINFO, '/path/to/cert')
    ->setOption(CURLOPT_FOLLOWLOCATION, true);
$response = $request->send();
You can also use setHeaders(array $headers) and setOptions(array $options) to replace all the existing options.
Note that some curl options are reset when you call send(). Look at the source code of the method cURL::prepareMethod for a full overview of which options are overwritten.
HTTP basic authentication:
    ->setUser($username)->setPass($password);
Laravel
The package comes with a facade you can use if you prefer the static method calls over dependency injection.
You do not need to add a service provider.
Replace $curl-> with cURL:: in the examples above.
原文链接:blog.csdn.net/jacke121/article/details/55549169
