php传输html乱码解决
风吹稻花香 发表于 2021/06/05 00:57:15 2021/06/05
【摘要】 发送:     $datas = $this->fhuiben_db->fetch_array();             $datas[0]['summary']=base64_encode($this->toUtf8(...
发送:
            $datas[0]['summary']=base64_encode($this->toUtf8($datas[0]['summary']));
            $datas[0]['content']=base64_encode($this->toUtf8($datas[0]['content']) );
           // $datas['summary']= json_encode($datas['summary'],JSON_UNESCAPED_UNICODE);
           // $datas['content']=json_encode($datas['content'], JSON_UNESCAPED_UNICODE);
//            echo  $datas[0]['content'];
echo JSON($datas);
publicfunction toUtf8($str){
$encode= mb_detect_encoding($str, array("ASCII","GB2312","UTF-8","GBK","BIG5"));
$str= iconv($encode,"UTF-8",$str);
return($str);
    System.out.println(getFromBASE64(returnResult.get(0).summary));
    System.out.println(getFromBASE64(returnResult.get(0).content));
    // 将 BASE64 编码的字符串 s 进行解码
        public static String getFromBASE64(Strings) {
        if (s == null) return null;
        BASE64Decoder decoder = newBASE64Decoder();
        try {
        byte[] b = decoder.decodeBuffer(s);
        return new String(b,"UTF-8");
        } catch (Exception e) {
        return null;
        // 将 s 进行 BASE64 编码
        public static String getBASE64(String s) {
        return (new BASE64Encoder()).encode( s.getBytes() );
原来是这个包:import sun.misc.BASE64Decoder;
import Decoder.BASE64Decoder;
import Decoder.BASE64Encoder;
原文链接:blog.csdn.net/jacke121/article/details/55293560
