php接收多层数组中文乱码解决
风吹稻花香 发表于 2021/06/04 23:38:33 2021/06/04
【摘要】 传参数:     Map<String, String> param = newHashMap<String, String>();                 pa...
传参数:
                param.put("biaoshi", "bjyz");
                param.put("action", "add");
                param.put("plan[week]", "1,2,3");//周一,周二,周三,多个日期用逗号隔开,单个就不用了
                param.put("plan[name]", "阅读asd");//借阅计划名称
注意:转换$_REQUEST后,就要用$_REQUEST参数,用post就不行,因为没转换。
举例:
'people'=> $_REQUEST['username'],
'mobile' =>$_REQUEST['mobile'],
'week' =>$_POST[order][week],
'memo' =>$_REQUEST[order][memo],
代码:
arrayRecursive($_REQUEST,"togbk");
function arrayRecursive(&$array, $function, $apply_to_keys_also =false)
foreach($array as $key =>$value){
if(is_array($value)) {
            arrayRecursive(
$array[$key], $function, $apply_to_keys_also);
else{
//echo $key. $function($value)."\n";
$tstr= str_replace(array("\r\n","\r", "\n"), "", $value);
//$str= togbk($tstr);
$str= $function($tstr);
$array[$key]=$str;
if($apply_to_keys_also&& is_string($key)) {
$new_key= $function($key);
if($new_key != $key) {
$array[$new_key]= $array[$key];
unset($array[$key]);
原文链接:blog.csdn.net/jacke121/article/details/55293671
